How is called that compound that glues components on the PCB?
    If someone can post a link, I will appreciate that.
    Re: How is called that compound that glues components on the PCB?
    solder??
      I agree, solder... or do you mean this:
      SMD assembly adhesive https://www.panacol.com/adhesive-app...r-smd-assembly
        No guys, not solder. The white stuff that looks like silicone/ETC or it is silicone?
        I am not sure that it is a regular silicone, I know that it's not supposed to be conductive.
          I attached a photo.
            thermal adhesive
              That is just silicone
                not exactly, it's NEUTRAL-CURE silicone.
                cheap crap has acid in it that eats the plating off wires & stuff.
                  No, I don't need a thermal adhesive, I need some kind of silicone to glue a capacitor that I have replaced.
                    dont use any silicone that smells like vinegar. i use black rtv, since it is easy to get for me.
                      use hot glue if it doesn't run hot
                        Electronics grade Silicone:
                        I.E. https://www.amazon.com/Clear-Electro.../dp/B07MKBBQTC
                          It's not just cheap silicone that uses acid. Most use acid. In my local hardware stores, EVERY silicone uses acid even the most expensive brands.
                          Some even say things like "Organic Acid" or "Low Odor" but those are still not suitable for electronics!! They are all designed for building, roofing, bathrooms etc.
                          It must be Neutral-cure designed for electronics, indeed.
                          -David VanHorn
                            I just bought some of this stuff for attaching heat syncs to chips ... and I could swear that any attempt to rip the heat sync off the chip once this stuff cures, it'll probably rip the chips face off before letting go... lol
