Happy new year.
New year, new challenge.
The goal is to upgrade my dv6000 motherboard [with gpu failing] from 8400m to 8600m GS and from 128MB to 512MB vram.
There where motherboards of dv9000 with 8600 & 512MB but for dv6000 the limit was 8400 & 256MB.
So I have replaced at the DV6000 m/b the chip with G86-771-A2 and removed 4 vrams and placed 8 of them from a old DV9000 m/b.
Next step is to fix the RAM configuration straps and the PCI device straps.
As you can see the two schematics are identical although they have different part numbers.
I copied the configuration from the dv9000 m/b and fixed the resistors like that.
Currently I have 2 issues.
Main is that it cannot detect hdds [also at bios menu], non from sata connector, non from hdd caddy. It is able to boot from dvd at the same time so something blocks it from working.
I booted at parted magic and was able to see the gpu configuration was recognized as 8600m GS but only 256MB.
So I guess system is not happy yet with the gpu and that's why won't see any hdd.
Bios programing also tested with no luck.
any guess will be helpful
