SONY KDL 43w805c does not accept commands
    Re: SONY KDL 43w805c does not accept commands
    Originally posted by Dobsuk View Post
    Yeah, i found the same but it looks it does not work. And can see the comments under the post, seems nobody has success with that rollback
    I tried and using your advice, Diah
    It looks i need to looking to buy Main board
    no need to buy new mainboards...
    take out the heat sink of the CPU and show what we have under it
      by the way... when it start at select language did you hear the music ? if yes you increase the volume or decrease from side panel... is there response and did you have notification bar ?
        Yeah, i can hear the music and the volume responds but cannot see notification bar every time. But he volume is working - i can turn it up or down even i can or not see the notification volume bar.
          take out the heat sink... it need heating to repair the BGA ... by removing the heat sink we can tell from which side (PIN ) on ship are responsible
            one things more before we go for heating... your photo https://www.badcaps.net/forum/attach...5&d=1610728654
            the side panel and led indicator IR receiver socket... are they connected with ribbon flat cable to the middle of the mainboards?? if yes... did you inspect under loop the end silver pins of the cable if any short or broken ???? yours issue very strange
              This is it:
                No, they are not with ribbon cables:
                  ok then heat this chip with hot air gun specially the middle to left side facing the plug which goes to side panel
                  when you heat it try dont move the boards ...leave it cool then put it back
                    I did in #27
                      For how long i need to heat it?
                        which heat equipment do you have ? show me to let the work being perfect this area i mean
                          Errmm, that is the problem. I do not have proper electronic hot air gun. I've got one bigger and i am not sure if i can use it for that.
                            dont worry LOL.... do you mean the one used for Pipe sanitary?
                              Haha, no not for pipes I think i can use my one:
                                okay ... but you need first to cover all around the chip for example the glue plaster used by wall or car painting... to avoid the blow hot air fly one SMT parts near to the chip.
                                after that let this gun to the maximum heat ,,,let it run far from the board until it reach the high temperature if it was 350 degree, then face it to the chip area and calculate 6 second .. such 11 , 12, 13, 14, 15, 16 then leave it cool down
                                  Done! Now i need to find my thermal paste
                                    try it before you apply the paste
                                      Can i try it without this heat sink just for 1min?
                                        you can for more than 10 minute too
                                          Nope, it is absolutely the same Shall i heat it again?
