Samsung UE40C6600 problem with power supply
    Hi to all
    i have the above model of tv
    It has power supply bn44-00355a
    the problem is it burns the two mosfet TK8A50 page 5 of service manual
    I change the two mosfets after measurements I made without being able to find any other problem and again burns the new 2 mosfet
    can any of you help me figure out where these two components can burn?
    Re: Samsung UE40C6600 problem with power supply
    Can you post the service manual so we can see what you are seeing?
      You likely have damaged gate drive components, check the DT1 to be sure the drive windings are not open, then check the resistors and diodes DM804 & DM805, you may need to lift one end to check them accurately
      You should also check the diodes on the TM801S secondary as one might have shorted.
        thanks sir i will check it and i will tell you about
        as about as service manual downloaded free from electrotanya
