asus x55A no power
    asus x55A no power
    Hello.
    Have this asus X55A and i have 19V before the first power mosfet and 0.89V after the mosfet.
    i cannot find schematic so any help would be needed
    Re: asus x55A no power
    find the qfn chips!
    model and see what they do.
    first is first did you find any fets broken or caps?
      i measure the charger ic bq24725
        maybe this can help you;
          already have it but its totally different hw
            when i inject 19V to base of first mosfet system works. there must be something that prevents ic to launch full 19V signal to that mosfet.
            charging led is on but no voltage goes to battery, but i dont know the life of battery
              Swap then.
              That ic opens with gate the fet for battery and adapter.
                i agree to dj_ricoh, try to swap these mosfet
                  mosfet is good. ricoh means swap ic
                    Originally posted by ktmmotocross View Post
                    Hello.
                    Hello friend.
                    That means your second PQ´s not activating, the first Mosfet is a Díode Mosfet and it doesn´t need the voltage on gate to activate, i may need 0v on pin 4 of second Mosfet to activate.
                    It looks like you don´t have +/- 6V gate sinal on second PQ.
                      i order some of these charger is because 5 laptops with DDR3 IN A ROW have bad this ic.
                      or if customer wont pay for replace i just inject 19V to ACDRV signal rail to have system work but without battery and charger.
                        I´d inject 6v to 9v on second PQ, that´s a PNP Mosfet injecting 19v may be too high.
                          Originally posted by dj_ricoh View Post
                          find the qfn chips!
                          may i know the qnf?
                            Originally posted by lorins_core View Post
                            may i know the qnf?
                            What is a QFN?
                              This is it QFN quad-flat no-leads
                              The bit that controls the charging/ input chip
                                Thanks for your answer, but can you please explain a bit more?
                                QFN is a enable pin that turns on or off the Charge IC?
                                  my computer does not come apart in wolt. 3v 5v I can not. I changed ıt8517. I changed the bq25. still no wolt
                                    I find second mosfet ,from dc_in konektor, shorted almost always...
                                      you fixed you laptop ?
                                      I have the same similar problem
                                        i have asus x55A
                                        my laptop completely is dead not even one LED all is off What is broken on my laptop
                                        can someone help me
