Isolation Transformer for TV repair
    I found this one on eBay, will it work for tv repair?
    http://www.ebay.ca/itm/B-K-1604-Port...item51cd02cb7c
    Re: Isolation Transformer for TV repair
    It is only rated for 1.25A, not really enough to run full load.
    May be enough to test the TV's or monitors in standby mode.
      ok, I would rather have a better one. Any suggestions?
        how many W do you need?
          doesn't matter as long as it can handle a TV.
            14inch lcd tv? 60inch plasma?
              I was told 750VA is good for TV repair, 42 to 60" plasma
                http://na.suzohapp.com/all_catalogs/...ies/80-2000-00
                120va
                  that tripplite looks seriously expensive!!
                    I use a 750VA continuous 1500VA peak iso xformer.
                    I modified it so the input and output grounds are not connected (so the chassis of the TV can be grounded or floating, useful for making measurements with a grounded scope.)
                      Also watch out and make sure it is truly isolated, some of the TRIPPLITE has Neutral tied to safety Ground.
                        cant you get big isolation transformers from power-tool company's for using tools outdoors?
                        we have them in Europe, but they are 120v output (60-0-60 centertapped to earth)
                          I've seen 240V isolation transformers with "power tool" ratings, if they're the same thing. (The power tool rating is an intermittent load, about 50% duty cycle.)
                            Most TVs these days are have isolated power supplies and unless you are going to test the hot side,a isolation transformer is not required
                              You do need to test Voltages on the primary side such as PFC Voltage booster, the STBY Primary side drive circuit, the Inverter (for PS/INVERTER COMBO) drive ciruits, etc.
                                That's what I said ,but you normally use a multimeter to test those voltages
                                but you need a CRO for xysus boards etc ,in this case a isolation transformer is not required.
                                  You could run 3 or 4, or more, of those in parallel, should cover just about any tv's power needs.
                                  When I was about 16 and extremely short on funds (IE, had to beg for money from my parents) I bought 10 35VA 120/12 volt surplus transformers from All Electronics. Wired all the primaries in parallel, and all the secondaries in series. Made a nice 350 watt isolation transformer for like $20 bucks. Still have it today, though I don't get to use it too often anymore.
                                    http://www.ebay.com/itm/Xentek-5205-...-/111658341077
