Ok. I have now come into my possession an Insignia (yeah yeah, cheap brand) 47" TV that, when working, will be on the outside covered patio.
Got it in unknown working condition.
Plugged her in. LED goes purple (Blue and Red at same time) for a split second, 5 red flashes and then solid Red. Power button on side does not affect the tv. Checked all the buttons, they are all open until pressed then I have continuity. No burn marks or smells of burnt electronics. Caps aren't swollen (not always accurate).
I do not have a remote for her.
I have uploaded pics of the boards and board layouts.
I think there is an issue with the Power board and here is why:
CN903 (left plug in pic) volt readings
Pin 1 on/off: --
Pin 2 DIM: --
Pin 3 12v: 12.5v then quickly falls to under 1v.
Pin 4 12v: 12.5v then quickly falls to under 1v.
Pin 5-7 GND: --
Pin 8 24v: 24.5v then quickly falls to under 1v.
Pin 9 24v: 24.5v then quickly falls to under 1v.
Pin 10 PS On: --
Pin 11 5v: 4.95v (steady)
Pin 12 5v: 4.95v (steady)
CN904 Right Plug Top, connected to bottom plug via trace on underside)
Pin 1 -5 24v: 24.5v then quickly falls to under 1v
Pin 6-10 GND: --
Pin 11 Enable: --
Pin 12 On/Off: --
Pin 13 Dim: --
This to me is telling me at first glance that the power board has some issues with voltage regulation. I attached the service manual. Let's see what I can find out about the 12 and 24v falling to under 1v..... I will entertain all ideas and troubleshooting.... It is my night to watch the kiddo so I couldn't devote too much time troubleshooting. Tomorrow night the wife has to watch the kiddo so I get more time. Thanks!!
Pin 1 on/off: --
Pin 2 DIM: --
Pin 5-7 GND: --
Pin 10 PS On: --
Pin 6-10 GND: --
Pin 11 Enable: --
Pin 12 On/Off: --
Pin 13 Dim: --
