Vox mini 3 amp
    Re: Vox mini 3 amp
    Thank you for the reply.
    I have attached top and bottom pics of the small board. Also attached a pic of the main board as well.
    Thanks again
      Re: Vox mini 3 amp
      Have you checked the resistor is ok? The only other thing would be the diodes.
        Re: Vox mini 3 amp
        Hi Midibob, I need to order one of your daughterbaords. Are they still available?
        can't see pm, can u send me an email
        tomasmauriciorueda@gmail.com
          Re: Vox mini 3 amp
          Hi, I'm afraid I don't make them anymore. I posted all the build details a little way back in this thread so people could make their own.
          Cheers
          Bob
            Re: Vox mini 3 amp
            Hi midibob, I'm wondering iff you still have one off your daughterboards, I've read you stopped producing, but just checking if perhaps you've made a new batch? I think you've made already a lot off people happy with it, so I was just hoping...
            Have a nice Easter Sunday
            Yvan
              Re: Vox mini 3 amp
              Hi Yvan, as the post above says I won't be making anymore.
              Happy Easter to you too.
              Bob
                Re: Vox mini 3 amp
                Hi Bob, was just hoping you might had one still lying around ;-) I going to try one myself thanks to your information post, but as I do not have the possibility to create PCB's I will try to build it on a breadboard. Should not be that complex I think, but not as compact as yours.
                What is the reason you went for a low ESR and how low should it be? I'll search Digi-Key for components this afternoon I think as it is a rainy day...
                Have a nice day,
                Yvan
                  Re: Vox mini 3 amp
                  No, they all went I'm afraid.
                  The low ESR cap was necessary otherwise there was internal feedback. I did document this way back in the thread. The type you need is shown in the installation instructions. I can't remember the exact one off the top of my head but if you're doing it on breadboard you won't be using SMD components anyway.
                    Re: Vox mini 3 amp
                    No indeed, I will not use SMD as I havent got the tools for it nor the capability of making PCB's, and as it is just a one of to repair our VOX amp. I think a breadboard wil do the trick, it will be somewhat larger but there is enough space.
                    I've found back in the thread you used 0,85ohm 10uf caps (SMD), the ones I've got on the order list is a 0,68ohm 10uF cap so it will be ok I guess...
                    Thanks a lot for all the documentation on this topic.
                    Cheers.
                    Yvan
                      Re: Vox mini 3 amp
                      Hi midibob! What a great job! My name is Adalberto, I'm from Argentina and I have the same problem with this amp!!! I'd like to know if there's any chance to get your daughterboard schematic and/or pcb to replicate it, just one time, just for my brother's amp.
                        Re: Vox mini 3 amp
                        I forgot to attach my email address since I'm fresh new on this forum
                        adalbertoledesma@gmail.com, any information will help. Thanks!
                          Re: Vox mini 3 amp
                          Hi Adalberto,
                          All the info is in this thread. It's very simple as the design is basically the same as the IC spec sheet.
                          Good luck
                          Bob
                            Re: Vox mini 3 amp
                            I have the same blown output and have read and downloaded all diagrams etc
                            The Midibob schematic just shows up as a windows file that i have not been able to open...yet!
                            Of course im also just learning how to repair electronics and it will be a good challenge for me.
                            Thx so much for all the work you have put in over the years helping everyone with this blown output problem midibob!
                            Hopefully someone more knowlegeable than i will be able to pick up the ball and help me get this thing fixed!!
                            Thx again
                              Re: Vox mini 3 amp
                              I think it was just a .bmp file which any graphics package will open ie Paint or even Word.
                              Glad the info has been useful.
                                Re: Vox mini 3 amp
                                Hi midibob, the amp is running smooth again... I've made it myself a little bit easy and ordered a little PAM8403 amp board, which is also 3W and piggybacked it onto the circuit board using your input for connecting. This was very straightforward and easy to do.
                                Thanks again for all the information which made this possible.
                                Cheers, Yvan
                                  Re: Vox mini 3 amp
                                  You're welcome, glad you managed to get it sorted.
