Cleaning Off Blu Tac
    Hi there
    Just a Tip..
    I had a Logitech Webcam that had rubber feet, which was on top of my monitor.
    It made such a mess on the base of the Camera, but I found that WD-40 cleaned it spotlessly.
    Thanks me later
    Re: Cleaning Off Blu Tac
    Be careful when using WD40 on plastic it can cloud the clear plastic
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      and it can de-laminate pcb's and make all the tracks peel off!!!
        Thankyou, Sam, I didnt know that
          Ohh..
          Thankyou stj
            You can sometimes use brake cleaner to remove glue but spray on the paper towel and wipe but if it is clear plastic it can also cloud the clear plastic test a small spot first
            You can sometimes use “ Goo Goo Glue and Tape Adhesive Remover ” but some time it might make the plastic tack-e to touch if you do not use enough of a few times but test it on clear plastic first to see if it makes it cloudy looking
            9 PC LCD Monitor
            1 Dell Mother Board
              WD-40 is 50% Kerosene aka jet fuel and mostly solvent Naphthalene aka lighter fluid, with a teeny tiny bit of mineral oil.
              Brakleen is 50% acetone, the rest naptha and toluene.
              Plastic chemical compatibility chart
                Thankyou Sam - Is Brake cleaner safe in plastic?
                I need to find something that cleans those double sided sponge things that almost weld to plastic
                  Hi Redwire - Has the WD-40 secret been leaked?
                  Excuse the pun.
                  I love WD-40 it has so many uses
                    for removing sticker glue i use white spirit - very cheap at toolstation
                    but test it on a hidden area first - it can fog some plastics and make pressed cd's explode!!!
                      You can see the chemical ingredients listed on the MSDS.
                      The worst mistake with WD-40 is thinking it's useful as a lubricant - it all evaporates fast.
                        Would anyone ever use WD-40 as a a switch cleaner?
                        I used to use Electrolube in the old days to clean Volume pots on TV's
                          WD40 is only good for spraying on rusted bolts outdoors.
                          and even that is probably not as good as 50/50 acetone and ATF fluid.
                            Thankyou stj
