Diagnosing EAX64905001
    Re: Diagnosing EAX64905001
    About the Mosfets, the original one was MDF11N65B and I've replaced it with an st 15NM65N
    The spec of the mosfet as a replacement does seem to be a very close match.
    If the original replacement was a metal back mosfet (Q101) that then blew I would be checking the bridge rectifier for damage and the components around IC101
    Look up Youtube on how to test the bridge rectifiers with your meter.
      Originally posted by nomoresonys View Post
      Some of your solder joints look a little funky as well, maybe touch them up.
      ok which area looks bad?
      The Mosfet\ motherboard output?
        They may be ok, I can't do it for you, the 2 links there show all manner of possible bad joints, just use your eyes and possibly finger to see if any are bad or loose.
          Ok, I'll try to test around the ic
          The bridge is ok as there's a steady above 300v
          When i testing the output voltage of the transformer (t101) there's nothing
          Anyway I'll try your suggestions during the week...
            components around IC101.
            Could you please advise me how to test the Mosfet ic? (IC101= SSC1S311 Sanken?)
            I saw on the Internet that sometimes it goes bad
              With the power to the set removed you could use your meter set to ohms and check the resistance of each pin of the IC. Leave the black meter lead connected to pin 8
              Pin 1 = xx ohms
              Pin 2 = xx ohms
              etc
                Pin 1 = xx ohms
                Pin 2 = xx ohms
                etc
                Ok so I've tried to test all the components resistance around the Mosfet & its ic
                And here's what I've found..
                These are 2 suspicious smd resistors ( both around the Mosfet ic) not sure if the Mosfet ic is bad or the resistors close to it are bad ( tested in circuit and I'm pretty afraid desoldering & resoldering them so i wond destroy them completely on that process [ but im assumes that I'll have no choice in order to find the culprit? to either desolder the IC \ these resistors,
                But I'm think that it'll be smarter to start desoldering the IC as long as you're thinking that he's the real culprit?! ]
                Anyway, here's the suspicious resistors + thier reading values
                1. Smd, r106; 0.838 K OHM (it has a writing of 221\ [ or 122? ] but looks more like 221
                2. Smd, r111; 176.2 OHM - out of 10k ohm = (it has a writing of 103)
                About the Mosfet ic results with the black probe on the ground
                Pin 1- 8.01 MEGA OHM ( with the round notch, parallel to the GND
                Pin2 - 0.994 K OHM
                ( pin 3, -NC)
                Pin 4 - when ive test it first few hours ago it showed me** 27.01 MEGA OHM, ** when I've retest& note myself the results -** it changed to " OL" - ** not sure if on the first time my meter lefts a little voltage there or IDK how it happens.. I'VE HAVEN'T PLUGGED IT IN for weeks, including today
                Pin 5- 78.9 ohms
                Pin 6- 0.838 K OHM
                Pin 7 ( vcc) keeps dropping down every time I've retest for the last few hours....
                It starts at 30.0 MEGA OHMS and keeps dropping down........
                Pin 8 ( GND )
                Thanks for your valuable time!!!! ❤
                  R106 should read 220 ohms
                  R111 should read 10K but may need to be lifted to have an acurate reading.
                  The other measurement should have had the black meter lead connected to pin 8 and have readings roughly as follows.
                  Pin 1 should read around 47K since it is connected to ground via R110
                  Pin 2 should have around 1K since it is connected to ground via R105
                  Pin 5 should have around 10K since it is connected to ground via R108+R111+R113
                  Pin 6 should have around 220 ohms since it is connected to ground via R106+R113
                    Ok so if I've got you there's a good chance that the ic is bad? if so then if ill desolder the IC I'll be able to retest these 2 resistors?
                    Or i have to desolder both?
                    And in case of accidently destroying the smd resistors, can I replaced them with standard 1/4w resistors ( with the same value + a little patch w\ shrinks + maybe low resistance piece of wires+ some hot\ silicone glue to secure them to the board?
                      Hi dick_barton, Do you have the PDF of the schematic or the whole service manual? Thanks.
                        Here you go budm.
                          Originally posted by diif View Post
                          Here you go budm.
                          Thanks!
                            At this point the SMPS IC is damaged due to the fact that R106 (220 Ohms current feedback) is blown when 300V is dumped into the IC via R106.
                            How about the Gate resistors and diode between Gate drive output of the IC and Gate of the MOSFET.
                            BTW, most of the time when that 1KV snubber cap is shorted out, the MOSFET will still be OK.
                              How about the Gate resistors and diode between Gate drive output of the IC and Gate of the MOSFET..
                              Dear budm,
                              Thanks for your reply too! ❤
                              Is that a question? ( sorry, my English & grammar arent that great as sadly, English isn't my primary language)
                              If so, then you mean to the;
                              R107
                              R111( bad)
                              R108?
                              D103- tested on circuit with 0.148v reading AT BOTH SIDES *BUT* I've compared it with my friend TV( same model, which works perfectly) AND HE HAD THE SAME result that's why I've didn't mention it ( because it's probably because it's texted on circuit?)
                              So you think ( as my assumings?) that the Mosfet IC(101) is bad?
                              If so, can i replace it with my older lg 32 lcd ( which had a bad MB? Or maybe another trashpicked TV if I'll found soon?
                              What's important when i swapping this ic?( min max V\ AMPS rating, pinout - is that pretty universal standard? etc,)
                              And in case that these 2 resistors are gone, may i replaced them with standard 1\4 watts( or higher watts? If so how much watt is necessary?) resistors with the same resistance + shrinks + piece of wire( is that gonna pass 300v? If so, it'll be safer + better to avoid or its just little current,
                              Mostly for communication & feedback? or i have to buy new smd's?
                              In that case, and for learning purpose, my tv was connected to my UPS at that time while i was working on my PC with the TV on standby, there wasn't a storm\ rain or something, and I've checked the UPS logging, nothing was bad with the electrical input, while I've read the original mosfet pdf's it states MTBF OF 5000 hrs ( = about 5 years = about the time I've owned it)
                              So do you have a clue \ guess how \ why it died? I'm not that familiar with electronics but in this case, i think that the Mosfet itself done his life and got shorted & blew up many components with it?
                              And another, last question for this reply ( sorry for that long comment, I'm just passionate to learning & bring it back to life 😀&#128591
                              I've trashpicked an lg hifi system ( pretty new model, manufactured only 2 years ago) with no power, the Mosfet + cap blew there too
                              My question is, can i replace brown "disk" capacitor with a blue disk capacitor?
                              It's harder to get the brown ones, is the blue safe(\ better?) to use? (ill use the same rating of course)
                              Thanks sooooo much for all of your help dear members!! 🙏🙏🙏🙏🙏🙏🙏
                                If you look ate the schematic, you will see that the Gate Resistor/Diode network (R108 (100 Ohms), R107 (22 Ohms), D103 are connected in series/parallel fashion, that it why when you test D103 you get reading in both directions. If the Gate components are tested bad that means the 300V is also dumped into the Gate drive output of the IC also.You do understand series and parallel circuit, correct?
                                You need to use the same SMPS IC, it is not standard IC.
                                That 1K snubber cap (connected in parallel with S-D of the MOSFET) failure mode is shorted circuit, it is commonly fail cap. I would replace it with 2KV rating instead, but for now you can use what you have.
                                  Hi Budm, I see Diff has sent you a copy of the same schematic I have.
                                    Ok, so to proceed with the repair, i have to order from eBay the ic? Is there a way to know if it's genuine?
                                    If I'll replace it with 2kw cap, in case of stress \ sparks\ storms etc, it can't further damage the other components? Or its opposite = in such case it wont bother at all the 2kw cap= it wont short the mosfet again? ( till it reach 2kw)
                                    Anyway, which value u suggest to use? 101/201?
                                    And can you please answer if i can safely replace a brown disk capacitor with a blue disk capacitor? With the same value? ( it's an trashpicked LG HIFI SYSTEM)
                                      Color doesn't matter as long as it has like value and as bud says, feel free to go up in voltage.
                                        Edit
                                        The schematic I have used shown above does not match the circuit board so ignore this post. Correct schematic given by diif post #31
                                          1) The 1K breakdown rating of that snubber cap C102 (330pF) is more likely at marginal rating, that is why I suggest to go with 2K rating so the cap will less like to fail shorted circuit again.
                                          2) The cap is connected in PARALLEL with Source and Drain pin of the MOSFET, it is not the cause of shorted MOSFET, if the snubber cap is not present, the MOSFET can be damaged. I do not know if you understand what what the purpose of the snubber cap is for.
                                          3) You have to use the same capacitance value as original, the value is based on the design of the circuit. Paint color of the cap does not matter, it is the capacitor type and rating of the cap that are matter. So what was printed on the body of the old cap C102?
                                          4) Your post #34"My question is, can i replace brown "disk" capacitor with a blue disk capacitor?" Are you talking about C102 since you never give us the designator of the cap? Show us the pictures of the old cap.
                                          5) Your post #37 "Anyway, which value u suggest to use? 101/201?" Which cap are you talking about? you need to give us the desisignator of the part. Where did you get 101/201 from?
                                          6) No way you can tell what you buy from AMAZON, EBAY, ALIEXPRESS are real or not.I buy most of my stuff from Digikey and Mouser for my own use and as suppliers for the company I work for.
                                          At this point I am not sure which cap you are referring to, you need to give all the designator of the parts you have replaced so far.
