Hello everyone. I have two Winbond chip: 25Q64JVIQ and 25Q128JVPQ. Please tell me, how can I read them? Is any adapter for programmer? I have programmer TL866CS with SOP8 socket, but I'm afraid it is not compatible. Photo of chip in attachment. Thank you.
W25Q128JVPQ HP BIOS Read Help
Re: W25Q128JVPQ HP BIOS Read Help
The chips are WSON8 ,you would need an adapter if you desoldered them.You can also get WSON8 and sop8 pogo pin clips.You can solder wires to the empty sop8 pads as well. The 2 bios chips aren`t supported by the TL866CS ,the latest TL866II does.The only way around it, if its the only progrmmer you own,is to find a cross compatible bios chip from another maker and check if its in the TL866CS support list, then program it as that.
https://www.gigadevice.com/products/...e-search-tool/
https://www.macronix.com/en-us/produ...ce-search.aspx
https://www.micron.com/support/tools...reference-tool
.Last edited by SMDFlea; 07-13-2020, 03:46 PM.
