hp550 bad graphic ic?
    hello.
    have this hp550 intel, that have strange problem. on start it freeze on windows desktop start and on wake from sleep. if i go to safe mode and than restart, it start total normal. do u think its a bad ic?
    Re: hp550 bad graphic ic?
    i flashed bios, try about 5 drivers. nothing helps
      could be some issue with gpu itlself and not the IC that manage the CORE .
      have you tryed making a clean new install on new hdd ?
        yes i make clean install. gpu is not in core.
          you mean there is no DSC , its gpu core come from cpu ?
            bether , ehhehe send motherboard code to be more understandable
              This laptop needs to be tested using Ultimate Boot CD.
