Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 08-27-2019, 10:16 AM   #3901
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: best cheap/free scores 1.1
Oh well, until I can find some suitable replacements for the small Wendells (22uF) , it's gonna be in a parts bin I have.
Meanwhile, I'm going to look into my EP45T-DS3R build (which is literally $10 total! - board was $6, PSU was $3) and look into a good GPU to pair it with. Already have 4GB of DDR3 (will add more once I can find some) and a Q9400 that was free from a friend who upgraded to a i3 3250/8GB DDR3 combo.
Main rig:
ASUS H61M-A
Core i3-3220 3.30GHz
MSI Twinfrozr GTX 750Ti 2GB GDDR5
6GB DDR3-1066
Samsung SH-224AB DVD-RW
Raidmax RX-500XT (recapped)
Seagate Barracuda ES.2 ST31000340NS 1TB
JNC RJA-52 case
Dan81 is offline   Reply With Quote
Old 08-27-2019, 01:17 PM   #3902
stj
stj's Avatar
City & State: Europe
i use tantalum for anything under 100uf
i use tantalum sometimes for larger stuff too - it depends on the voltage.
Old 08-27-2019, 03:15 PM   #3903
Curious.George
A pair of hot tweezers. Not the best quality but for component removal they won't be bad.
Curious.George is offline   Reply With Quote
Old 08-28-2019, 06:05 PM   #3904
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
Originally Posted by ajshoe View Post
amazing how a .50 cap can put a $800 washer to the curb !
yupp thats cost cutting at its finest for you! to paraphrase what u said, its amazing how a 50 cent cost cutting measure can trash an 800 dollar machine. all to save 0.0625% of the total cost of the machine!!
ChaosLegionnaire is offline   Reply With Quote
Old 08-28-2019, 06:57 PM   #3905
stj
stj's Avatar
how much do they want for a new board?
i bet that has a big roll in this.
Old 08-28-2019, 09:30 PM   #3906
dmill89
City & State: Harrisburg, PA
Line Voltage: 120VAC 60Hz
Depending on the model $200-400, add in an hour or so labor for the repair guy (generally the minimum charge even if it only takes 15 min to swap the board) and you are looking at a $300-500+ repair (unless the owner has the ability to fix the bad cap themselves, a repair guy is just going to swap the board) so it is easy to see why someone would junk a 5 year old machine that needed a repair costing half as much as a new one (though ridiculous and wasteful that appliances have gotten to this point of being effectively disposable).
dmill89 is offline   Reply With Quote
Old 08-29-2019, 05:15 PM   #3907
dmill89
An Ariens 8524 2-stage snow blower for $110. It needed the usual tune-up stuff (carb kit, spark plug, belts and sheer pins) but after that the Tecumseh Snow-King fires up on the first pull (has electric start too) and it runs great. This thing is built like a tank, has to be 14-16 ga. steel, unlike most of the new ones that are glorified tin-foil that bends if you look at it wrong, and cheap plastic.
Old 08-29-2019, 07:54 PM   #3908
Curious.George
(sigh) I miss snow. When you can choose when to clean the driveway (instead of having to clear it "before work") it's really a fun chore! Also, amusing to watch all the other folks trying to get around in the stuff...
I gave away my 5HP Honda before moving. I don't think I ever used the electric starter, that puppy ran like a champ! I should have pulled the engine and found another use for it... 5HP should have been roughly enough for a 3KW genset!
Old 08-29-2019, 11:51 PM   #3909
dmill89
Since I have a 4WD truck with good ground clearance I can generally make it to work without having to clear the driveway (and if we get too much snow for my truck to make it through the office will probably be closed anyhow). That being said I can't wait too long to clear snow as I have sidewalks (and a large corner lot so a few hundred feet of sidewalk to clear, hence the snow blower) which Township ordinance requires I clear within 48 hours of the end of the storm.
Old 08-30-2019, 12:03 AM   #3910
Curious.George
The "rush" to get it done before driving on it was motivated by the near impossibility of removing the snow once it had been compressed under the weight of the tires -- once departing for work and then, again, when returning home. And, the fear that any rain or daytime warming would result in that turning into a block of ice when it refroze.
So, I'd wait until the morning rush was over before even thinking about going outside (I like to sleep late :> ). And, if possible, wait until the plow had been by so his pass wouldn't undo my efforts at the curb!
Old 08-30-2019, 04:29 PM   #3911
Curious.George
And The Purge continues! One of three boxes of RAM that I recycled, today. Just over 15 pounds, total. (I really need to figure out how to get better pix with that silly phone!)
Yippee! I'm probably well past the 1,000 pound mark, now...
Old 08-31-2019, 04:53 PM   #3912
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
Today's freebie is a 42" Vizio TV. Satellite provider told them it was shot (over the phone) after a storm fried the dish receiver, they went and bought a new one. I didn't even have to take the back off. Works like a charm, all inputs.
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 08-31-2019, 06:47 PM   #3913
Curious.George
Cool! Once rescued a Sharp TV that was "locked up". Reflashed the firmware and it was good as new (unfortunately, "new" was synonomous with "buggy piece of shit!")
I got a DSO (TDS754D) cuz the metrology lab failed to properly seat the "connector PCB" (think of it as a passive backplane). Open cover, reseat board, close cover -- done!
Old 09-01-2019, 04:32 AM   #3914
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Scored another free and nice Soyo SY-6BA+IV after my SY-6VBA133 bit the dust. I tried everything to bring it back but it's dead. Oh well, VIA chipsets aren't really my favourite (trying to keep it 440BX as possible) so a Intel 440BX chipset is really welcome, as well as the HPT366 RAID controller. Guess this could compete with a BH6 or BE6-II? :lolsign
Here's a photo. The standby LED was broken off, and it had some pretty bad cut traces that were leading to the RAM slots that I managed to fix by tinning them with a bit of solder. Replaced the long dead CR2032 with a new 2032 that measured 3.02V, and everything's okay now.
As for the Wendell caps on this one, I'm not taking any chances at replacing them for now.
At least the ones around the CPU have a big copper plane that literally sucks up all the heat my 40W iron can put out, so I'm not keen on replacing any of them at the moment. Also, I don't have any good 8x20mm caps at the moment (planning on using 1500uF 6.3v Panny FL caps)
Old 09-05-2019, 10:05 PM   #3915
Curious.George
Another batch of these little "solid state disks". I had assumed they were just DoMs but, apparently, they claim to be SSDs!
https://www.prosoft.ru/cms/f/443843.pdf
Of course, they're too small to really be useful as such. And, the "housing" seems to be a third-party modification...
Old 09-05-2019, 10:29 PM   #3916
Topcat
The Boss Stooge
Topcat's Avatar
Those would be stellar for HTPC's!! If some happen to show up here, I wouldn't be offended!
Old 09-06-2019, 03:19 AM   #3917
Curious.George
I've been stuffing them in my t610 thin clients. I run them diskless AND headless!
They normally PXE boot from a server I have in another room. But, from time to time, I misconfigure things and I won't be able to "talk" to it (over the wire). Then, have to drag out a monitor and keyboard to see what the thing is complaining about.
With these SSDs -- small capacity as they are -- I can put a complete BSD on each machine and configure the boot order to be "PXE" followed by "disk". So, if the PXE boot fails, the "disk" can provide an OS that can talk to the outside world without the need for a monitor/keyboard for troubleshooting.
I'm not sure they'd be of much use in an HTPC as you still need a disk to host your content (?). But, I'll watch for the next batch that comes in.
BTW, I've a box for you that's been sitting in the living room (pissing off my other half!) for several weeks that just hasn't made it to the Post Office. I only "get out" one day a week and do so early enough that the PO isn't yet open. On my return, it has been too damn hot (110F) to make a side trip there -- I just want to get back home and cool down as I've been out in the heat up 'til then.
I will try to make an effort to get to it this coming week. Which will cut down on some of the grumbling I'm subjected to... <frown> (I'll PM when I get 'er done)
Old 09-06-2019, 11:44 AM   #3918
Topcat
The Boss Stooge
Topcat's Avatar
Awesome!!
Old 09-07-2019, 06:38 AM   #3919
dragos2009
City & State: Craiova
My Country: Romania
Line Voltage: 220VAC 50Hz
i wish i had as much ram as there is in the picture
dragos2009 is offline   Reply With Quote
Old 09-07-2019, 02:14 PM   #3920
Curious.George
Memory is insidious. You scrap a machine and you immediately think of pulling the memory (for some dubious future need). And, toss it in a box for when that day comes.
And, you do this over and over again -- sometimes pulling "old" memory from a box to fit some need. But, more often, just letting the pile build (cuz newer machines want newer/bigger sticks).
In order to effectively dig through that pile, it has to be kept sorted: specialty memory separate from more conventional; "laptop" from desktop from server; different technologies and speed grades, etc. So, it takes up even more room than it might, otherwise.
[I keep memory sorted into 10 18"x6"x6" boxes filled with ziploc and "altoid" tin so it's a full shelf "wasted" on memory!]
Cables are almost as insidious. They're easier to sort -- but take up a lot more space.
So... to reclaim space, the cable and memory collections are the first target! (How many spare VHDCI cables does one really need to keep on hand??)
