Old 09-23-2009, 12:27 PM   #41
EGuevarae
EGuevarae's Avatar
City & State: Chiriaco Summit, CA - near the AZ-CA Border
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: Dell E153FPB Back Light problem
Originally Posted by freakytiki4u
What is the proper way to test the Transistors? I noticed they have 3 legs each. I tested with my Ohm meter and there are differences but I would like to know specifically what Im looking for and how to properly test to determine defective ones.
Check this page.
  • ASUS ROG Maximus IX Code
  • Intel Core i5-7600K 3.8GHz
  • Windows 10 Pro x64
  • GeForce GT1050
EGuevarae is offline   Reply With Quote
Old 09-23-2009, 12:46 PM   #42
Bobdee
City & State: WALES UK
Testing out of circuit with MM set on Diode Check
Red probe on B and Black on C, Should read about 600
Red probe on B and Black on E, Should read about 600
Testing for shorts between pins set MM to Buzzer and check
B + C
B + E
C + E
Probes both ways
Bobdee is offline   Reply With Quote
Old 09-24-2009, 02:51 PM   #43
freakytiki4u
Coolest Member
freakytiki4u's Avatar
City & State: Live Oak
My Country: United States
Thank you for the info. I tested and found bad transistors. I ordered a few kits from Ebay and after repair the Monitor is working just fine. A friend gave me 2 more 19" monitors and I have also repaired them. I found several cold solder joints too and fixed those also. Thanks to all of you who helped and if I can ever do anything for you just ask. I will try my best.
freakytiki4u is offline   Reply With Quote
Old 09-24-2009, 03:37 PM   #44
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
I'm a: Hobbyist
Congratulations!!!
Old 09-24-2009, 05:34 PM   #45
EGuevarae
EGuevarae's Avatar
Originally Posted by PlainBill
Congratulations!!!
I second that. And for helping us, you can help all of the members & readers just posting your experiences. Your experience here might provide advice to new members, or not so new members that had not fixed this particular model. I guess that would be enough.
Old 09-25-2009, 10:33 AM   #46
Geordieboy
I have just aquired an E153FPb which was showing a green light but no display. After reading this thread I tried the fuse PF751 and that has brought the backlights on. However there is no display. Enthused by moving a stage forward I did a bit more googling to see if I could find any similar experiences and came across the folowing:- http://www.elbase.ru/files/cd/monito.../BENQ%20FP531/ This is an index of Benq technical sheets, diagrams and fault finding flowchart for the Benq FP531. The E153FPb is based on the Benq FP531 (denoted by the b). There are some variations depending on the LCD manufacturer (eg. LG, AU) This may prove useful to anyone visiting here in the future. I am currently trying to source the components I need locally and if the thread is still running when I've got them I will leave an update.
Geordieboy is offline   Reply With Quote
Old 09-25-2009, 11:02 AM   #47
Bobdee
Welcome Geordieboy
Badcaps does not close Threads its always glad to recieve new Info at any time
Look forward to your update
bob
Old 11-03-2009, 09:56 AM   #48
freakytiki4u
Coolest Member
I have a Dell E173FPs. Symptoms: Green power light just flashes quickly. No picture at all. I found 2 swollen caps and replaced them, still same thing. Green light just flashes quickly. The Power and Inverter board is model # IP-35135A (photo attached.) Anyone have any ideas what may cause this? I am looking for cold solder joints in the meantime. I have found it a good idea to just go ahead and resolder the transformers anyway as cold solder joints are so common. Srry if this is considered hijacking the thread.
Old 11-03-2009, 11:28 AM   #49
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
Suspect shorted transistors in the inverter. A picture (larger if possible) of the bottom of the board will help us identify them. I'm curious, please post the picture even if you locate them yourself.
PlainBill
Old 11-05-2009, 09:21 AM   #50
freakytiki4u
Coolest Member
Im having trouble uploading better pics due to size. Not sure how to make them the right size. lol
Old 11-05-2009, 09:35 AM   #51
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
I use Hamrick Software's Vueprint. (http://www.hamrick.com/upg.html) It makes cropping and reducing resolution of pictures easy. I'm sure there are other products that work as well or better; it's the one I'm familiar with.
PlainBill
Old 11-05-2009, 09:58 AM   #52
freakytiki4u
Coolest Member
I downlaoded the trial but it watermarks. lol, anyway I could email the pics to ya?
Old 11-05-2009, 10:56 AM   #53
EGuevarae
EGuevarae's Avatar
Try Fotosizer. You drop in an image, specify a new size either in percentage of the original or in pixels, and it resizes it either replacing your original or saving it to another place (or the same place with another name). It is what I sometimes use when I have to meet size (either in Kb or in pixel dimensions) reqs.
Eduardo
Old 11-05-2009, 11:53 AM   #54
freakytiki4u
Coolest Member
will do, ty very much
Old 11-05-2009, 12:00 PM   #55
freakytiki4u
Coolest Member
Eduardo
Wow, ty, very very easy to use and free, cant ask for more than that! lol Pics are attached as you asked ofr.
Old 11-05-2009, 12:30 PM   #56
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
I've edited the picture of the bottom of the power supply. The first step is to measure the output voltage. The red lead of your meter goes to the pins at the upper right I've circled in red, the black to the pins circled in black. This should be done with the power supply hooked to the logic board of the monitor. It may be easier to probe from the top.
I also circled two ICs in blue. If these were shorted it could cause the problem. What is the part number of the ICs?
PlainBill
Old 11-05-2009, 12:45 PM   #57
freakytiki4u
Coolest Member
Voltages are solid 10 volts testing each pos with all 3 neg. Same 10 volts on all.
Numbers on IC's are the same. Each has 4501GM and S05034 (might be 505034, hard to tell they are so small)
Old 11-05-2009, 12:56 PM   #58
freakytiki4u
Coolest Member
I did not have the bulbs hooked up when testing voltage incase that makes a difference but it was hooked to the logic board.
Old 11-05-2009, 02:17 PM   #59
PlainBill
PlainBill's Avatar
I'm a: Hobbyist
10 volts is a problem. It should be 5 volts. If you were using an analog meter it might be on the wrong range (user error), but if it's a digital meter and set on the 20 volt range, that's an accurate reading. 10 volts may have fried the logic board. BIG trouble.
PlainBill
Old 11-05-2009, 02:52 PM   #60
freakytiki4u
Coolest Member
I checked again on 50 volt range with analog meter, still reading 10 volts, checked on 10 volt range reads maxed out, just a hair over 10 volts AC
