Issue with Westinghouse 19" LCD Monitor (large pics)
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    Originally posted by mobaar
    Holy crap....it worked.
    Bridged the fuse with solder?
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • mobaar
      • Mar 2009
      • 18
      #42
      Yep. Amazing that we both had the EXACT same issue. Wonder if we should make Westinghouse aware of it, it has to be some sort of weakest link in the system.
      I apologize, but did not get the voltage readings on the MOSFETs before I closed it up. I hope to get on that in the next day or two.
      Thanks again for everyone's input! Hopefully this can walk someone else through another expected issue with this inverter board.
      Collin
      • EGuevarae
        • Nov 2008
        • 1336
        Collin
        Same board, same problem, same solution so far. What bothers me is why?
        And I understand you were so anxious to start using it after you first noticed the backlight turned on. I contained myself, but if it was your first, I guess you didn't.
        Congratulations.
        I'm glad I was of any help to you.
        Just post a pic of the working monitor, please (for my records) if possible.
        - Eduardo
        • GeForce GT1050
        • baffleonious
          • Mar 2009
          • 2
          #44
          I have the monitor you two have been working on open in front of me, but am still unsure as to which fuse I put the jumper on....? Might you provide a photo..I have two of these monitors sitting around my work and am hoping they'll let me take one home!! Thanks, I hope..
          Will
          • EGuevarae
            • Nov 2008
            • 1336
            Will
            Welcome to BadCaps.net, Will
            The fuse we are referring in previous posts is the one in the red rectangle :
            This pic was posted by me before. I just wanted to make it easier for you to get to it.
            Did you check the MOSFETs and the caps already?
            - Eduardo
            • GeForce GT1050
            • Bobdee
              • Jun 2008
              • 461
              #46
              nice one guys,
              I have never seen a fuse on solder side of board before,
              new one on me, thanks
              • EGuevarae
                • Nov 2008
                • 1336
                Originally posted by Bobdee
                nice one guys,
                Thanks, BobDee.
                I have seen them before on PS2 Slim and in an Acer 1916s that has the same PSU/Inverter board as this Westinghouse.
                You learn a lot around here, either experimenting, following advice, or expanding the scope of the things you see or look for in a failing/defective unit.
                • GeForce GT1050
                • baffleonious
                  • Mar 2009
                  • 2
                  #48
                  Well, this is bad...I guess I inferred that I could bypass changing the Mosfet(s) (plus I'm unsure of which Capacitors to change...) by just jumping the one fuse. Such a simple solution I though, "I can do that!" but alas it looks like I'll have to put a bit of elbow grease into it...I guess I'll take the busted monitors home and hopefully figure out what the hell to do. On the other hand, I just assumed we had the same problem do to the similarity of symptoms but have done zero diagnostic work...and have never really done diagnostic work...So...in conclusion...I have a lot to learn and know not where to begin. Thanks for the efforts though. (if you have a ups acct number and want two westinghouse monitors...let me know, otherwise they're probably trash)
                  • Bobdee
                    • Jun 2008
                    • 461
                    #49
                    Hello Baffleoious,
                    please dont trash them,put them on your local freecycle,
                    or something like that,
                    better still put them to one side and have a good read on the badcaps forum,
                    they will be a good start to learn on ,as you have two of them,
                    • DrGr33n
                      • Mar 2009
                      • 3
                      #50
                      Hi
                      I just registered to say thank you to all the knowledgeable people here. I was/am having the same problem as described in this thread. With the information picked up from here I intend on giving my monitor a second shot at life. Thanks again guys.
                      Cheers ;-)
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        Originally posted by DrGr33n
                        Hi
                        Cheers ;-)
                        Welcome to Badcaps.Net
                        If you need help, post some pics, more info, and wait for either the feedback or requests for more info.
                        • GeForce GT1050
                        • DrGr33n
                          • Mar 2009
                          • 3
                          #52
                          Thanks for the welcome. Just posting to say that I followed the advice I picked up from this thread and had success in reviving the old 19in Viewsonic monitor. My 14 year old son is now enjoying it's second life, trouble is he now wants a better video card to play his games at 1400x900. Sheesh. No pleasing some people. Anyhow thanks again for the help.
                          Cheers ;-)
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Cheers ;-)
                            Been there. After the Video card, the HDD would be too small, the processor would be too slow, and in the end your wallet will be too empty
                            • GeForce GT1050
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Too true. One bright side: 'Last years' technology is often available at bargain basement prices. I've picked up high end socket 478 motherboards with 3 Ghz HT CPUs for less than $50. My last acquisition was an ATI video card with 256 Meg of RAM as a Craigslist freebie. Works perfectly.
                              PlainBill
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Any news on this, baffleonious ?
                                • GeForce GT1050
                                • Welchs101
                                  • Sep 2008
                                  • 979
                                  HI,
                                  I am also having the same problem with my westing house monitor. The fuse F200 was "open" so i replaced..........and after i turned on the monitor it still did not work. I checked the fuse i just put in and it opened. So i have a short somewhere. I have a question about the BIT3713. I measure GND on pins 7 and 13
                                  Pin configuration is below:
                                  1,16
                                  2,15
                                  3,14
                                  4,13
                                  5,12
                                  6,11
                                  7,10
                                  8,9
                                  I think pin 7 is the actual gnd but...........i am not sure about 13.........
                                  Three questions:
                                  1) How to determine what is causing the short which continues to open up fuse F200?
                                  2) Anyone know if pin 13 on BIT3713 should be GND
                                  3) Anyone know where to find replacement for BIT3713?
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Originally posted by Welchs101
                                    HI,
                                    1,16
                                    2,15
                                    3,14
                                    4,13
                                    5,12
                                    6,11
                                    7,10
                                    8,9
                                    Three questions:
                                    Welcome to the forums.
                                    Post a picture of the inverter/PSU to see if it is the same it is/was discussed here.
                                    • GeForce GT1050
                                    • Welchs101
                                      • Sep 2008
                                      • 979
                                      exact same pic as was already posted by eguevarae on 03-07-2009, 04:17 PM
                                      • Welchs101
                                        • Sep 2008
                                        • 979
                                        the monitor is a westinghouse L2046NV
                                        • EGuevarae
                                          • Nov 2008
                                          • 1336
                                          Good to know that I am being referred to my own pictures .... while that helps, one tries to find bulged caps, uneven colors or other signs of failure. And as your LCD is a 2046NV just like mine, I suggest that you check the MOSFETS in my thread about the 2046NV, or open a new thread.
                                          • GeForce GT1050
                                          • Cuboy
                                            HP probook 4510s mosfet issue
                                            by Cuboy
                                            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                                            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                                            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                                            03-16-2024, 10:29 AM
                                          • ebyte64
                                            Lenovo IdeaPad 330 laptop mosfet issue
                                            by ebyte64
                                            Good day everyone.
                                            I have been scratching my head with a Lenovo laptop I got in today.
                                            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                                            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                                            Would anyone...
                                            06-27-2023, 10:19 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • DqMagetz
                                            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                            by DqMagetz
                                            Good day!
                                            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                            Here are the voltage readings:
                                            • Input – 19V (stable)
                                            • +LCDVDD – 3.3V briefly, then drops to 0V
                                            • EDP_HPD – 3.3V briefly, then drops to 0V
                                            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                            • EC BKOFF# – 1.8V briefly, then drops to 0V
                                            • PANEL_OD_EN – 0.3V
                                            Is it possible that the EC chip is corrupted or damag...
                                            Yesterday, 09:37 PM
                                          • wattage
                                            AOC AG493UCX 49-inch monitor - Firmware request
                                            by wattage
                                            Hello Badcaps Community,
                                            I purchased a preowned AOC monitor that is not working and out of warranty. It was sold as not working. I am looking for guidance on self-repair. In particular, I am after the firmware for the monitor. At the end, I have included monitor model information and links to pics and vids of the issue.
                                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                            Today, 04:41 PM
