Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
  • bonney
    • Oct 2008
    • 74
    #41
    Re: Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
    I can get both P2804BDG and P5504EDG
    • dt2rz
      • Oct 2010
      • 30
      #42
      http://forum.allaboutcircuits.com/sh...ad.php?t=21285 tells that
      the FETs or transistors are OK to use.
      • gybruss
        • Oct 2010
        • 5
        #43
        Please tell me where?
        • gybruss
          • Oct 2010
          • 5
          #44
          Originally posted by dt2rz
          Replaced the following parts on the inverter board:
          -10 caps with 100uf 25v 85*c 2000 hour Chemicon SMG
          -Q3 & Q4 with FDD6690, i can't find original P2804BDG
          -Q5 & Q6 with FDD6685, i can't find original P5504EDG
          Result is still the same. I tried checking the CCFLs one by one and all are
          lighting up fine. Can somebody guide me in testing the power supply. Here
          are some more pics of the power supply...
          i am not sure, but i looked at the specs for the fdd6690 and does not match the specs i think this is the problem. wrong fets.
          • bonney
            • Oct 2008
            • 74
            #45
            dt2rz on the two fues's on the inverter whats the in voltage and the out voltage
            • dt2rz
              • Oct 2010
              • 30
              #46
              I don't really know how to check properly, can you tell me how? Here's a picture of the DMM i'm using.
              • bonney
                • Oct 2008
                • 74
                #47
                Set it up how you did to check the power from you power board
                read this http://www.doctronics.co.uk/meter.htm#digital
                • dt2rz
                  • Oct 2010
                  • 30
                  #48
                  With monitor powered off, put DMM to 20M ohm setting i get 0 ohm on both fuse.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Set the DMM to 200 ohms, not 20 Megohms.
                    PlainBill
                    • dt2rz
                      • Oct 2010
                      • 30
                      #50
                      PlainBill
                      DMM set to 200 ohms, both fuse read 00.4
                      • bonney
                        • Oct 2008
                        • 74
                        #51
                        now test the fuse with power on
                        • dt2rz
                          • Oct 2010
                          • 30
                          #52
                          f2 = 30.7
                          f3 = 1.2
                          • bonney
                            • Oct 2008
                            • 74
                            #53
                            can you check does the power go through the blue coils then to the fuse?
                            • dt2rz
                              • Oct 2010
                              • 30
                              #54
                              How to check these? What DMM setting to use and where to probe black & red wires? Sorry I'm a rookie.
                              • bonney
                                • Oct 2008
                                • 74
                                #55
                                ok before we do that can you do the fuse's again but both ends
                                • severach
                                  • Aug 2007
                                  • 1055
                                  Flip the inverter upside down and hook the lamps up in reverse order. Does the dim part switch sides? Does the part that was formerly dim appear to light up properly?
                                  N Channel FDD6690A seems a satisfactory replacement for the P2804BDG. The hard part is finding a good replacement for the P-Channel P5504EDG. Too far out of spec and the inverter will shut down. Parts that do run can run hotter than the originals.
                                  Niko-Sem parts are easy to get in China.
                                  sig files are for morons
                                  • dt2rz
                                    • Oct 2010
                                    • 30
                                    #57
                                    There is no dim part, all the lamps lights up together. Test it one by one, also lights up. Anyway i tried your suggestion and all lamps lights up like before. I'm wondering why the monitor goes to standby after 'no signal' shows up in screen. Other folks have the green light all the time, just the backlights shutting off By the way, sorry for hijacking your thread.
                                    • mathog
                                      • Mar 2010
                                      • 2655
                                      #58
                                      Every monitor I have does that. It is a power saving feature. At least it is if there is really no signal - if it does that when there is video going into it then there is a problem.
                                      • mathog
                                        • Mar 2010
                                        • 2655
                                        #59
                                        Can you get into the menu before it shuts off? Some monitors will stay lit if you press the menu button right after it is powered on, even with no video signal. Others (for instance some Viewsonics) will not go into the menu if there is no video signal and will blank anyway.
                                        • dt2rz
                                          • Oct 2010
                                          • 30
                                          #60
                                          I can not access the menu...
                                          • black6host
                                            Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                            by black6host
                                            Good day!
                                            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                            I'm going to replace the caps and I'll be the first...
                                            02-06-2024, 08:22 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                            Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                            by momaka
                                            I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                            For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                            https://www.badcaps.net/filedata/fetch?id=3591771
                                            https://www.badcaps.net/filedata/fetch?id=3591772
                                            It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                            https://www.badcaps.net/filedata/fetch?id=359177...
                                            03-12-2025, 03:42 PM
                                            Westinghouse L2210NW LCD monitor - bad caps repair
                                            by momaka
                                            Here's another LCD monitor repair: Westinghouse L2210NW.
                                            Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                            I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                            Pictures of the monitor outside/case after a brief...
                                            01-11-2021, 01:14 AM
                                          • eryjus
                                            Heathkit IO-4205 Power Supply Caps
                                            by eryjus
                                            First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                            I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                            I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                            05-10-2023, 11:21 AM
