Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 09-26-2021, 04:34 AM   #1
Stuckster
City & State: Sydney
My Country: Australia
I'm a: Knowledge Seeker
Default TCL 65" U65E5800FS - Black shading after startup
TCL Model U65E5800FS (AUS)
D65A620U (CN equivalent)
My 65" TCL just started doing something strange. I searched the forums but couldn't find any threads covering the exact issue (possibly not using the right keywords).
When I turn it on the title screen displays normally... a brilliant, consistent white with no artifacts and the TCL logo in the middle.
Within 2 sec to 2 min the left and right side of the screen go dark, creating a vignette with only the centre illuminated.
Same issue using my PC as the source.
I have tested the issue with two separate sources using two different HDMI cables in all 4 HDMI ports. Same result each time. So it points to a hardware issue with the TV.
I assume it's not a problem with the backlights since the title screen it fine.
I also assume the T-Con is ok since the picture is still normal (albeit dark).
I suspect this problem is similar to the seemingly common issue others have experienced with just one half of the screen going dark. But thought is was worth running it by everyone in case it was something new or different.
Would it be something like a failure in the voltage supply to the backlights? Something that works correctly for a little while then gives out? Bad capacitor for example?
Any suggestions or help with troubleshooting would be much appreciated.
Many thanks
Stuckster is offline   Reply With Quote
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
