Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 09-28-2021, 04:50 AM   #1
angelos
City & State: Free State
My Country: South Africa
Line Voltage: 220V AC
I'm a: Professional Tech
Default JVC TV Model LT-65N675- No picture
Hi guys,
This set has no image. The back lights are running but the TCON seems dead.
The fuse on board is ok, 12V is present. The problem seems as if there are voltages missing but due to weird markings I cannot see VGH clearly. Anyway, I disconnected both ribbons feeding the panel to see if my voltages come up but they don't. Up to know I was looking to purchase a complete used tcon board but they are not available.
Can anyone who knows these sets guide me so that i can diagnose the fault. I believe it to be the DC to DC buck converter.
I have a image not to good quality but now that I know that i need to repair it i will remove it and zoom into its design.
I think JVC might be similar to your RCA products
Any help would be greatly appreciated.
angelos is offline   Reply With Quote
Old 09-28-2021, 05:02 AM   #2
angelos
Default Re: JVC TV Model LT-65N675- No picture
The chip RT6931 below has 5 solder spots marked CPOUT, UH, UL, LH and LL and there is 0V on all 5 when set is running.
Is the UH actually VGH???
Check photo
Old 09-29-2021, 10:45 PM   #3
angelos
Any help anybody?
Old 09-30-2021, 11:33 PM   #4
angelos
I measured some voltage points and these are the results
VONE = 0V
STV2 = 0V
VIN_1.2V = 1.23V
VL = 0V
UL = 0V
LL = 0V
VH = 0V
The pico fuse has 12V on both sides
The big chip in the centre reaches 50 degree celsius in 2 minutes.
All these voltages were taken with both panel ribbons disconnected.
I measured resistances on all SMD caps and could not find any shorted ones.
This board is unavailable and on the web i find this board but it is for a Sony TV. I doubt the software will be the same and thus i will not order it.
I guess this tv is going to the landfill.
Old 10-05-2021, 11:12 PM   #5
angelos
What a dead forum!!!
Old 10-06-2021, 01:49 AM   #6
yokoono
"VIN_1.2V = 1.23V"
VIN is the supply voltage of the t-con and must be 12V. The fuse is blown or the motherboard does not power the t-con. If the safety is burned, you have an excessive consumption on t-con.
yokoono is offline   Reply With Quote
Old 10-06-2021, 07:59 PM   #7
R_J
City & State: ☻
My Country: Canada
There is a solder spot labeled HVIN3_12V (next to ICB1?) do you have +12 volts there?
R_J is online now   Reply With Quote
Old 10-07-2021, 12:24 AM   #8
angelos
Quote:
Hi, yes i will check that on saturday and get back to you
Regards
Old 10-07-2021, 12:25 AM   #9
angelos
Quote:
Originally Posted by yokoono View Post
"VIN_1.2V = 1.23V"
Hi there,
I don't understand your reasoning. The label says 1.2V and i am getting 1.23V so that is spot on.
Old 10-07-2021, 12:35 AM   #10
yokoono
VIN is the supply voltage and is 12V not 1.2V. Measure at both ends of the fuse (F1) and see if you have 12v.
Old 10-07-2021, 12:44 AM   #11
diif
City & State: Midlands
My Country: England
Quote:
Originally Posted by angelos View Post
Hi there,
Perhaps inspect that marking with some magnification. It's a via not a.
diif is offline   Reply With Quote
Old 10-08-2021, 02:15 AM   #12
angelos
Ok, I will take a proper photo of it and also test it tomorrow when I am back in office.
Thanks so far.
Old 10-10-2021, 08:07 AM   #13
angelos
Hi Guys, i did further tracing around the voltages that are missing on the TCON and i noted the following. When mains power is applied to the tv the TCONs ribbon supply voltage from the main board is a steady 12V if the set is on standby or ON. This tells me that something else must switch on the 12V when picture is required. I have made some marking on the photo i sent you to explain properly.
ICA1 i assume is either a mosfet or a dc to dc converter, i dont know. What i do know is that when i removed the ICA1 i saw that 4 circuit tracks are common as the 12V input and one is on the output called HVIN_12V. The last pin is a bias pin or enable pin and is driven directly from the RT6931GQW IC.
I was monitoring the HVIN_12V pin when applyuing main power and it shot up to about 3.3V and dropped to zero. It never came up again.
If i measure ohms from HVIN_12V to ground i get 38.5 k ohms so there is no short there.
So here is my conclusion either RT6931GQW is faulty or goes into protection or who knows maybe there is no data from the main being detected by this chip so it does not start up???
The TV lies open awaiting your help.
Thanks so far.
Old 10-10-2021, 08:08 AM   #14
angelos
here is the picture!
Old 10-10-2021, 10:03 AM   #15
yokoono
Problems where it is surrounded by red?
Old 10-10-2021, 12:09 PM   #16
angelos
Thanks Yokoono,
I saw those coils.. The plastic tops have cracked or perished. Probably from heat. So you agree with me the RT6931 chip might be the problem? So I will order it and hopefully it fixes the issue.
Old 10-10-2021, 12:19 PM   #17
diif
My Country: England
The IC next to the damaged coils also looks damaged as does the component above it.
Old 10-10-2021, 12:41 PM   #18
R_J
City & State: ☻
My Country: Canada
Those coils are not plastic but powdered iron (or similar) The side of the ic looks damaged as well, this is not from heat but from something striking that part of the board.
Old 10-10-2021, 11:29 PM   #19
angelos
I will replace that chip and see what happens! Will take months for the part to arrive.
Old 10-10-2021, 11:49 PM   #20
angelos
Or maybe order a complete board via Ebay and hope it works.
Just a question, if the board arrives and I fit it and there is something wrong like the picture is flipped upside down or some other issue. I remember somebody telling me that there is a program loaded into the tcon. If so then would it be fair in saying that i could unsolder the old eprom and solder it into the new one and it could then work?
I think the eprom could be part "ICE11" or is it loaded into the big square chip in the centre?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
