Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 11-20-2021, 03:16 AM   #1
akc1956
City & State: Sakon Nakhon
My Country: Thailand
Line Voltage: 220VAC 50Hz
I'm a: Hobbyist Tech
Default Mosfets for P600W24V Smps
Hi, I have a 24v 600w SMPS from a cnc/engraver machine. It has stopped working, No power from the supply. I opened it up and found the main rectifier, 2 mosfets, and 2 current sence resisters all blown. I can find the bridge rectifier and resistors but not the mosfets. They have the number 600R160 on them but i searched everywhere on internet but unable to find any datasheet or info to get equivalent. The only reference I can find to 600R160 is for resetable fuses. Can anyone advise me as to what a replacement might be. I have attached photos if its any help. Thanks in advance for any info.
akc1956 is offline   Reply With Quote
Old 11-20-2021, 06:29 AM   #2
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Default Re: Mosfets for Smps
This is something that need to brought in this post because this brand of power supply are found for a lot of engraving and 3D printers so if you are having this issue already this might start popping more often
Thank you for posting this issue with your switching power supply for your machine
Because I have this same exact brand on my 3D printer but I have recap mine already
I do not recognize the ic manufacturer logo on this device but I suspect that it is priority in nature and you might not find a replacement for it unless you can find another circuit diagram that is very similar to the circuit board design that you have in this switching power supply board
You might be better off buying a mean well brand switching power supply and try to buy one that has a higher current capacity than the one you have or at least the same current capability
If you can not find one and you have to buy the same brand again recap the switching power supply board with name brand capacitors so you can avoid failure like this in the future before you even plug it in for the first time
But if mine has a failure like this I already have found a replacement for it and I am posting a website link to it
https://www.ebay.com/itm/16409247129...53.m1438.l2649
Yes they are a little pricey in nature ( for even a new one ) that is why I have this item in my wish list
You can find these switching power supply on the internet and should be easily found
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 11-20-2021, 07:08 AM   #3
victorcas
City & State: MŠlaga
My Country: EspaŮa
Line Voltage: 230VAC 50Hz
Default Re: Mosfets for P600W24V Smps
The manufacturer of IC is "Wu Xi China Resources Huajing".
It seems to be hard to find on the internet. Source:
http://www.ecadata.de/herst/myshowlogo.php?F_SPRACHE=2
Can you measure the size of the mosfet?
I am not sure if they are mosfet, because the part number does not match other mosfet part numbers from that company. They use "N" between the numbers instead of "R".
If those are mosfet they are probably 600V 16A. Maybe you can replace with one with the same or greater parameters and check if its work.
An example: STW25NM60ND
victorcas is offline   Reply With Quote
Old 11-20-2021, 07:23 AM   #4
sam_sam_sam
My Country: USA
Thank you for identifying the manufacturing logo and the manufacturers logo identification website link I have an older version of this and not all of them are on it
Old 11-20-2021, 08:46 AM   #5
lotas
City & State: Sochi
My Country: russia
600r160 - hpf600r160pc-g
File Type: pdf Huajing Micro Electronics Product Catalog 2019v3.pdf (2.16 MB, 12 views)
lotas is online now   Reply With Quote
Old 11-20-2021, 09:54 AM   #6
sam_sam_sam
My Country: USA
Quote:
Thank you for the information here we go again with the manufacturer not putting the complete part number on the devices
REALLY why do they keep doing this short cut
Old 11-20-2021, 12:05 PM   #7
akc1956
Thanks to everybody for all the replies and info. I should be ok finding an equivalent now. I have already got a replacement complete supply from the machine manufacturers under warranty but still would like to fix the old one for a spare in the future.
Old 11-20-2021, 12:33 PM   #8
sam_sam_sam
My Country: USA
Quote:
I am glad that you got a replacement for the one that was defective and I am with you about trying to fix it
But I would highly recommend that you recap this board before you really start using the replacement one because they have off brand capacitors and there are know issues with quality of them
If you want a list of good quality brands and what series to use for this switching power supply just post a picture of the capacitors that are in this switching power supply
Old 11-20-2021, 12:57 PM   #9
akc1956
I also found a video on YouTube by a crazy Czech guy about a write up and test of 600w 12v Smps which looks almost exactly the same as mine apart from the input filtration. This one has IRPF460A mosfets. I will check these out for similarities to mine I watched a lot of his videos and although a bit crazy he seems to be quite a knowledgeable and entertaining chap. The first photo is mine and second is his.
https://youtu.be/DzM3-bnotgQ
I also have a couple of bulging caps to replace.
File Type: jpg E72FCA7D-A37C-4E8A-978F-8AA2DF5A98BA.jpg (179.5 KB, 9 views)
File Type: jpg 6124BA5F-A285-4633-9DAD-A15F8941A0C3.jpg (216.3 KB, 10 views)
Old 11-20-2021, 01:05 PM   #10
akc1956
Thanks Sam, will get some pics tomorrow. Iím in Thailand so itís 2am here now
Old 11-20-2021, 04:28 PM   #11
sam_sam_sam
My Country: USA
Yes I have seen his videos before and he is a little nutty but I do get a lot out of his videos that I have watch before I do not think I have seen this one though but I am going to watch this one as well
Old 11-20-2021, 09:39 PM   #12
akc1956
There are 3 videos on this one supply: whatís inside, full load test and analysis+transformer autopsy. Very interesting.
Old 11-20-2021, 09:56 PM   #13
akc1956
Hereís the pics of my capacitors. The supply was for a Hictop Idex 3D printer, not CNC/engraver as I originally said.
File Type: jpg 604B2B07-613F-48FB-9080-065B84666E8C.jpg (301.8 KB, 11 views)
File Type: jpg 27F2D1DE-27D9-479B-9717-DD78786A65B4.jpg (313.6 KB, 9 views)
File Type: jpg 78206419-96C7-49F3-9D2B-BC2AF963DF83.jpg (366.7 KB, 9 views)
Old 11-20-2021, 09:57 PM   #14
akc1956
Here’s the pics of my capacitors. The supply was for a Hictop Idex 3D printer, not CNC/engraver as I originally said.
Old 11-21-2021, 04:20 AM   #15
sam_sam_sam
My Country: USA
Yes these are non brand name capacitors but if they are the main filtering capacitors they might be alright but if they look swollen in any way do not trust them to be good anymore any capacitor that it’s voltage is less than 100 volts I would highly recommend that you replace them with name brand capacitors if they have a UF value of 100 or less replacing these are very important to be replaced
Old 01-03-2022, 12:31 PM   #16
faraday28
City & State: Jakarta Pusat
My Country: Indonesia
You dare to disrespect legend? ))
Most chinese smps use surplus component, so let's say they have big surplus of E13009 in China, well they will use E13009 almost in every design of their power supply.. That's why they tends to keep up the lowest price, and actually it helps a lot e-waste
faraday28 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
