GPU Caps Out of Spec?
  • itachi
    • Mar 2018
    • 27
    My friend has this EVGA GTX770 GPU that, after 7 long years of use, is now starting to act up with artifacting and causing random black screens requiring a hard power down.
    I decide to check the caps, since I've revived other GPUs by replacing bad ones. Physically they all look fine. These are all very low ESR caps, like aluminmum polymer <=10 mhom and tantalum polymer in the range of 20-30 mohm. They all test fine ESR wise.
    They're grouped as follows:
    4x 270u 16V Al-polymer
    3x 100u 16V? tant-polymer
    9x 330u 2.5V tant-polymer
    4x 470u 2.5V tant-polymer
    The odd thing is, all 9 of the 330u range from about 208u to 247u. They clearly have "330" marked on them in large numbers, but they all seem to average to around 220u. The ESRs all test 20 or 30 mohm. Does anyone know if that's a sign of them failing, or are these actually 220u caps in disguise.
  • PeteS in CA
    • Aug 2005
    • 3578
    • USA, Unsure of Planet
    Re: GPU Caps Out of Spec?
    Polymer caps don't have a liquid electrolyte that can evaporate over time. BTW, the dielectric in an electrolytic or polymer cap is not the electrolyte or the polymer. The dielectric is a layer of aluminum oxide on the surface of the anode foil. The electrolyte-soaked paper or polymer is a conformal conductor between the cathode foil and the aluminum oxide surface.
    Some ultra-low impedance electrolytics have had problems with the electrolyte attacking the aluminum oxide layer, but I've not heard of problems with the polymer affecting the aluminum oxide layer.
    PeteS in CA
      • 30948
      maybe they are breaking down slowly because of the ripple current.
        Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
        by momaka
        I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
        For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
        https://www.badcaps.net/filedata/fetch?id=3591771
        https://www.badcaps.net/filedata/fetch?id=3591772
        It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
        https://www.badcaps.net/filedata/fetch?id=359177...
        03-12-2025, 03:42 PM
      • eryjus
        Heathkit IO-4205 Power Supply Caps
        by eryjus
        First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
        I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
        I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
        05-10-2023, 11:21 AM
      • Paxman_Swede
        Identifying caps on an old Zoom 9000
        by Paxman_Swede
        Hello!
        I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
        The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
        I have studied the board and...
        01-14-2025, 09:51 AM
      • captain150
        Help with switching power supply caps
        by captain150
        I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
        I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
