Neighbor has a constant drain on his car battery...
  • UglyBetty
    • Jan 2022
    • 20
    Re: Neighbor has a constant drain on his car battery...
    Your correct, Acura is Honda....not Toyota. My mistake. Everything else still applies.
    • WebK
      • Dec 2021
      • 9
      • France
      This fuse is for OBD2 Pin16(+batt permanent).
      Try unplug fuse (7,5A), check no voltage on Pin16(OBD2) and resistance to ground.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • drscoot
        HP X360 convertible battery blown fuse error, not charging
        by drscoot
        HP Modelnumber: 14-dh0061nb​
        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
        All these 3 batteries are charging...
        12-15-2023, 05:54 AM
      • gboone
        820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
        by gboone
        Hi, I was given this laptop by my uncle who said:
        • It would occasionally shutdown if not plugged in
        • battery had been replaced
        • touchbar would "strobe"
        I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
        After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
        BUT
        When powered off, it would at some point have a...
        01-27-2025, 09:12 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
        09-14-2023, 11:10 PM
        ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
        The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
        configurable for operating as either a Hybrid Power Boost (HPB)
        charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
        4-cell batteries. Both configurations allow the battery to work with
        the adapter together to supply the system load when it exceeds
        the adapter capability, referred to as system Turbo mode. HPB
        charger configuration reverse-boosts battery energy to the system
        bus to help the adapter provide the system power in Turbo mode.
        NVDC charger configuration...
        11-05-2024, 03:28 PM
