Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Thread Tools Display Modes
Old 11-25-2014, 02:45 PM   #1
wepouaout
City & State: Utrecht
My Country: Netherlands
I'm a: Knowledge Seeker
Default How to find the right capacitor for my 70's film projector
Today the capacitor connected to the motor of my 1970's EIKI SL2 16mm film projector broke down. While running a film the projector suddenly slowed down and came to a halt very slowly. At the same time I heard a hissing sound from within. When I opened the back of the projector I noticed a yellowish wax-like substance was pouring from the top of the very hot "sh condenser", which I believe is also called a capacitor, connected to the motor. Don't know what caused it, but the projector had been out of service for a while before I ran it today. It may well be coincidence, a normal end of life.
Needless to say I'd like to get it fixed again. The capacitor seems like something replaceable, but the broken original being a 1960's version I am not sure how to identify the correct modern replacement.
The original was made by Nidec and reads "SH CONDENSER 2.3uF 500 WV AC Nidec". It connects to a 220-240V 0.7A Nidec AC induction type electro motor with a 144-168W power consumption.
I had a look around on internet to find a suitable replacement, but had no luck finding one with the exact same specs. I don't know how much, of if at all, I can deviate from 2.3uF 500 WV. So my question is what could be a good replacement capacitor spec. Maybe you guys can help get me in the right direction.
wepouaout is offline   Reply With Quote
Old 11-25-2014, 03:08 PM   #2
goontron
5000!
goontron's Avatar
City & State: South Greeley, Wyoming
My Country: US
Line Voltage: 13.9kv HT service and some 240v center tap oddity.
I'm a: Professional Tech
Default Re: How to find the right capacitor for my 70's film projector
Its a common HVAC runcap.
__________________
Tomorrow Is Nearly Yesterday And Everyday Is Stupid!
goontron is offline   Reply With Quote
Old 11-25-2014, 04:03 PM   #3
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
How many leads go into it - how many pins inside.
selldoor is offline   Reply With Quote
Old 11-25-2014, 04:52 PM   #4
wepouaout
Number of leads on top: two. One is connected to a red wire, another to a grey wire.
Old 11-25-2014, 04:57 PM   #5
wepouaout
I also have a circuit schema that shows how the red and grey connect.
Old 11-25-2014, 05:13 PM   #6
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
what's on the top?
spade connectors, solder terminals? or just wires coming out of glue?
and what's the length and diameter?
stj is offline   Reply With Quote
Old 11-26-2014, 01:18 AM   #7
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
I think you would get away with a 2.2uF or a 2.5uF 500VAC unit in this case.
__________________
japlytic is offline   Reply With Quote
Old 11-26-2014, 03:55 AM   #8
selldoor
Slow Learner
selldoor's Avatar
Just a query but could he use one of these:
http://www.ebay.com/itm/Black-3uF-50...-/231291666780
Old 11-26-2014, 04:39 AM   #9
stj
stj's Avatar
there are no shortage of motor caps,
it's just a matter of getting the best fit - hence my question about how it's connected to the wires.
Old 11-27-2014, 03:27 AM   #10
wepouaout
stj, it is attached to the wires by solder terminals. See attached photo.
Based on the suggestions I've received so far, I'll be looking for a 500VAC between 2.2uF and 2.4uF or possibly 2.5uF. I've now found some of those units on eBay, as selldoor suggested. I am a bit familiar with soldering and proper wire insulation, so it shouldn't be a problem gettings things connected.
Old 11-27-2014, 03:30 PM   #11
stj
stj's Avatar
http://www.rapidonline.com/Electroni...Run-Capacitors
you see here, they come in several styles - so choose the easiest one to fit.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
