Pioneer Magnetics PM33 5000W switchmode supply
  • Andrealikescaps
    • Dec 2013
    • 17
    Hello friendly Badcaps community. I'm repairing a 5000W switchmode power supply. Pioneer Magnetics are being incredibly unhelpful, so I'm all the more determined to fix it anyway . Would anyone have experience with these supplies or know where a circuit diagram may be found?
    Cheers.
  • Andrealikescaps
    • Dec 2013
    • 17
    Re: Pioneer Magnetics PM33 5000W switchmode supply
    No takers i see, well Meanwell make similar supplies so I will look into shoehorning one in for now, but if anyone in Australia would like to try to repair one of these supplies I'm happy to offer to pay.
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      5,000W power supplies would be well outside of the experience of most folks here. I think the highest I've worked with is 3000W and not from Pioneer Magnetics. My limited experience with Pioneer is from the early 1990s. If they still do as they did then, beware of schematics they provide users. They often have intentional inaccuracies to hinder reverse engineering.
      PeteS in CA
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        by sam_sam_sam
        03-31-2024, 02:12 PM
        by sam_sam_sam
        07-01-2024, 06:34 AM
      • CMCM
        Russound CA4 Power Supply Repair
        by CMCM
        Hello Everybody,
        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
        The outputs marked 12v and 20v are all measuring only 1v.
        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
        The capacitors physically look clean (no bludgesor leaks) and...
        07-03-2025, 01:12 PM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
