HMMM....What could this be.... ;) TC's first X8DAi Build!
    Re: HMMM....What could this be....
    Originally posted by thesloc View Post
    No SSD = fail
    unless you have an INCREDIBLE amount of money, SSD's don't have near a good price/GB ratio of regular HD's.
    you can buy a 1TB HD for $69, or a 1TB SSD for $1400+
    you could also, in this case, get like 4 256M SSD's and set them up in raid 0 for like 1G
      Originally posted by Topcat View Post
      Are you serious?! SSD with critical data = fail. I'll stay with my spinners.
      Yeah, true, but what about speed/access? As far as back up goes, I guess the next logical step is the Cloud...
      Although it can become in a PITA to restore spinners (or $$ if the damage is really bad)
        I backup my stuff on multiple local RAID1's. It would take a quadruple failure or more for me to actually lose data. Site stuff is backed up in a similar fashion, some on-site, some off-site. I never did jump on the SSD bandwagon. When a SSD fails, recovering data is impossible. A trusty old spinner, unless the head grinds the platter into dust, you can usually get your stuff before it completely dies. The raptors are pretty snappy....
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          Well in that case you might also want to make BD-R back-ups.
            Agreed that good old spinners can't be beat... I love my old 2006 era 74GB 10K raptors (although 1 has 26 bad sectors ). IF I tried to SSD it, it would be $$$ for 4 drives and it would be less relaible (my controller is also SATA150)
            My 9500-S may need a battery... it occasionally gives a fail status on the BBU upon bootup. It has the original battery too...
            sigpic
            (Insert witty quote here)
              In case you guys haven't noticed, thesloc is just a massive troll. He knows everyone's points of views on most things and what buttons to push. Best to just ignore him.
                You are absolutely correct.
                Team : 49813
                Join in!!
                Team Stats
                  Just a little point to make note of....When I replaced the battery and got it charged/tested/etc, I noticed the system was performing like crap. Drive access was miserably slow, and I really thought a RAID was dying. In the process of checking the SMART data via the controller software, I noticed that all the settings for both arrays were set to the most failsafe/conservative modes. Write caching disabled. I guess when the battery dies, it does this automatically to potentially avert dataloss....but boy does it make the system perform like poo. I put everything back where it needed to be, and YAY!! My system came back to life!!
                  Team : 49813
                  Join in!!
                  Team Stats
                    these two know how it works!
                    yep like trying to mock linux in a post about how even ballmer says the surface sucks. where did anybody say linux?
                    Follow the white rabbit.
                      Not quite. Those were probably just the default settings...
                      My first "real" computer was a 486 DX 33 with an AMI BIOS. When I upgraded to a P200, I made a classic mistake. I merely used the auto-detect for the HDD. I formatted and installed win95. I later realized that LBA would make for better performance. So I changed "CHS/AUTO" to "LBA."
                      Guess who had to reformat and reinstall?
                      It was one of those funny "VXTWO" boards and it had a battery connector that liked to be intermittent. I was always paranoid of the BIOS defaulting and giving me boot (in the head) problems. After a year or two of that, I soldered and "adjusted" that battery holder.
                      Somehow, that system lasted til late 2007, when I junked it.
                      "pokemon go... to hell!"
                      EOL it...
                      All style and no substance.
                      guilty,guilty,guilty,guilty!
                      guilty of being cheap-made!
                        I thought the same thing, but actually its not. Write caching is on by default. it will be disabled by the controller only if the BBU is not present or malfunctioning. You can actually re-enable it again without the BBU working.....but the first time it crashes or loses power while the system was on, it probably won't boot anymore. I had an old adaptec U2 SCSI that would do that.....
                        Team : 49813
                        Join in!!
                        Team Stats
                          Go for it, man! After all, since "it's not your data anymore," it'll only be a couple days before you "self-incriminate." You know, as in pull a TrayFaceBookVon.
                          Make my day, put all your "evidence" in the cloud. It won't be the only thing in the cloud. Like how your head's in "d clouwdz." Specifically, talking about transfer rates/latency and how that pertains to mass storage, but while blathering nonsense about "the cloud," forgets about a nasty little "inconvienence." That would be your Crapcasts, unClears, Veriz0nes, etc. The cloud-this, the cloud-that, all the while your "managed" upload rate is that of a floppy disk. On a good day. Then, there are those customers who are at the end of the line for DSL (damn slow link), and the signal is too weak or has too many reflections (old/sloppy wiring?). Sorry, but "The Clout" (there's lots of it) won't even beat ZIP-100 disks...
                          Sure, because mine always go bad on me...
                          I don't know what's funnier- that or Mr Thug knocking the "Microshaft Coffee Table," which by the way, is sooo 2010...
                          His next thread will be how we should all "accept and tolerate" the XBone.
                          EOL it...
                            I love SSDs...
                            Here you can see my Intel RST software keeping an eye on the array, my WEI scores (back when I just built my computer, that's why the screenshot is a different window theme color than now, but the benchmarks are still the same). Also see a benchmark I just took while streaming Netflix, running about a hundred tabs in multiple browsers, and doing other things as well.
                              Originally posted by shovenose View Post
                              I love SSDs...
                              you need 10 3TB HDDs to get 28TB RAID how many SSD would it take?
                                Doesn't matter because I can just upload to my servers
                                  for your servers smart one!
                                    Um... I undersell my shared/reseller servers and VPS nodes, so I've got plenty of extra disk space. I could upload all of my data that I own to any one of them.
                                      I hate server/cloud backups. Too slow to access when you only have a 5Mbps internet connection and a 25GB download cap.
                                      SSDs are great for the OS and software, but not large amounts of data. That all belongs on a pair of mechanical HDDs (either RAID 1, or manually copied/pasted to an external).
                                        the two SSDs i have owned failed within three months of purchase the intel went read-only and the OCZ just dropped dead out of nowhere. no SSD for me thank you!
                                          Their stupid, blaring commercials never tell you this! And ClearChannel, "IHeartRadio," etc, wonder why FM broadcast is in the toilet in the US...
                                          A few months ago, carbonite had a bit of a "cloudburst," where so many TB of data "went somewhere." Oh well, ain't the cloud great?
                                          Never mind the fact that any user data uploaded is scanned through to determine the users' "interests and habits," in the name of advertising, of course...
                                          Sorry, "the cloud" can snow for all I care.
                                          EOL it...
