Did I just bought a fakecap ?
    • 30965
    Re: Did I just bought a fakecap ?
    how wide are the 1800uf caps? 8mm or 10mm
      • 30965
      Check the polarity of the capacitors: you installed them backwards.
      Asus are crazy and uses the half circle on the PCB to designate the positive side.
      See for example:
      https://www.badcaps.net/forum/showthread.php?t=10480
      https://www.badcaps.net/forum/showthread.php?t=16890
      they dont always do that - which is actually worse because you need to note the details before you pull the old caps - or go searching for pictures afterwards.
      • xnRS
        • Feb 2021
        • 85
        • Belarus
        See for example:
        CRAAAAAAAAAAP, FORGOT ABOUT THOSE xD got the same issue on Asus GPU yesterday
        • xnRS
          • Feb 2021
          • 85
          • Belarus
          8x20(Width x Length)
          • xnRS
            • Feb 2021
            • 85
            • Belarus
            Funniest of all that K58 Kemet caps survived...
            • xnRS
              • Feb 2021
              • 85
              • Belarus
              #26
              And the board worked for a long time... You know... 3 days...
              • xnRS
                • Feb 2021
                • 85
                • Belarus
                #27
                So, after desoldering caps what I got is:
                3 died panasonic(probably not) caps, each of them lost half 800 uF of their capacity(Finally got at least LCR-T4), and got high ESR
                1 out of 4 Kemet caps died on desoldering, as one output lead desoldered(or what it has done) from the cap too. Other Kemet caps survived and still got good ESR in range from 0.07 to 0.11 and 360-380uF capacity
                  • 30965
                  a polymer with 0.11ohms sounds so wrong!
                  • xnRS
                    • Feb 2021
                    • 85
                    • Belarus
                    #29
                    they are 330uf 6.3v, will check the datasheet for these Kemet A758
                    • xnRS
                      • Feb 2021
                      • 85
                      • Belarus
                      #30
                      So from datasheet it says ESR at 100 kHz 20°C is 16 mΩ
                        • 30965
                        0.016 is a lot less than 0.11
                        • xnRS
                          • Feb 2021
                          • 85
                          • Belarus
                          #32
                          yea I know
                          also, btw, can you give me a link to a poly caps pls
                            • 30965
                            best i'v found in 8mm so-far is 1000uf, but i'm still looking
                            • xnRS
                              • Feb 2021
                              • 85
                              • Belarus
                              #34
                              I think this is would be hard one, as polymers are more wide and more low, so I found only 10mm 1800uf one...
                                • 30965
                                1500uf will be fine, but i suspect we wont find more than 1200uf.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  #36
                                  Of course they're fake.
                                  I have never seen Panasonic FL sold to the masses that were genuine, nor are they even manufactured any longer.
                                  • brethin
                                    • Dec 2008
                                    • 1907
                                    You got faked, keep crying.
                                    • xnRS
                                      • Feb 2021
                                      • 85
                                      • Belarus
                                      #38
                                      wow, so toxic, funny man, get out of that forum. Noone wants to see you there
