LG 55UJ6200 BEFORE & AFTER tape fix/fine tuning success
    I have an LG 55UJ6200 that cycles between sickly green, full color and back again with some lines and random banding at the top of the screen. After watching https://www.youtube.com/watch?v=pfrRhw7-ZII I was motivated to attempt this right away and got some pretty good success. I am using a huge piece of tape blocking a whopping 20 pins on the second cable in the tv. Only problem is after about 40 minutes or so the set gives a little random flicker - enough to be distracting. I am making this post to see if anyone has had a similar failure with this model and what pins are the ideal ones to block and which to never block. Might be quicker than trial and error.
    Now in the video he is able to cut down his tape and isolate the issue to just one pin. Now that's difficult in my opinion as you must slice the tape off the cable and risk cutting the traces so I am applying the tape a little bit at a time. Here are the before pics.
    Re: LG 55UJ6200 BEFORE & AFTER tape fix/fine tuning success
    AFTER results. Also I have included a picture of the tape amount I used as well as a picture of the connector coming out of the mainboard in case someone can advise based on what they see for my next attempt.
    The panel does not appear to be cracked but there is a short in it somewhere based on what I've heard from youtubers. These modern panels are flimsy if they can't even last 3 years under normal use. Total power on hours: 918
      So these are the corresponding connections I am blocking in the signal for the best result so far.
        After testing for more than an hour the flicker has returned. So the tv will function for the length of a tv show before it shows issues. Also I got the power on hour count wrong, it was actually 619 hours. How ridiculous is that for durability?
        Last edited by Noobwithamultimeter; 05-06-2021, 06:30 PM. Reason: forgot something
          You can try testing resistance of the MLCC (Multi Layer Ceramic Capacitors) on the tab bonding boards to see if any of them show low resistance reading.
            Ok I'll try if I get into it further, but for now I've noticed I can make the flicker go away if I use a smaller piece of tape. But when I do this the fine lines appear more noticeable. So it's a tradeoff between flickers or fine lines. I think I prefer the fine lines, flicker is much more distracting.
              I don't want to remove it now since I've got a good image going, so here is a picture in case I change it. Appears to be first 12 pins covered.
                I'd have to take a apart the frame to get at them. Are they repairable/replaceable?
                  Bad caps can be replaced if you have experience with SMD repair and have proper tools.
                  Example of bad MLCC:
                  https://www.badcaps.net/forum/showth...44#post1043044
                    Crazy. I have it narrowed down to 4 leads covered now. Working on a smaller and smaller piece of tape. Color is correct but there are lines still. Getting very tricky with these tiny pieces of tape.
                      Can you trace where they feed too ?
                        My best guess is pins 11-14 are affected because I can see a solid image with them blocked, although there are quite a few lines in the image. Also the color is correct. Blocking other lines causes the left side of the image to go kind of slightly lime green due to the yellow being off instead of yellow.
                        Here is where I think the lines lead to on the mainboard. There is no t-con board in this set.
                          The lines pull though a via to the other side of the pcb a magnifying glass would be a big help, they also feed too another part of the board on the top. I’ve seen even the smallest of MLCCZ caps fail short, easy to test multimeter on ground and measure each side.
                            So it's possible the failure is mainboard related? Could be a mlcc on the mainboard or on one of the gate driver tabs? I think the tabs are very tricky to solder on.
                              LCD TV will have T-CON. It can be stand alone T-CON board, integrated T-CON into the LCD panel, or integrated T-CON into the main board.
                              Can we see the pictures of the whole back side of the TV showing all the board.
                                You’ve almost narrowed it down to the panel, start doing some resistance checks.
                                  The mlcc's are integrated into the panel. Only problem is I'm nervous about getting the outer frame off as I can't find any youtube guides on this model yet, also once I get there I have no replacement capacitors.
                                    Put the Tv on the table on a cloth screen upwards, go around it take the screws out, remove the frame bit by bit or if it’s a solid frame start lifting at the end opposite to the drivers and pcb. Needle DMM probes are advised as you don’t want to put a load of pressure of the small parts with larger probes. I’ve fixed a SONY 55” 4K set that had 1 shorted ceramic cap in a bank of like 20 in parallel it takes time, having an LCR meter can help track down the lowest point of resistance too.
                                      Ok back at the frame removal, here is a photo of the whole back and I've indicated what line I've been tape masking with different results.
                                        So I removed one long metal guard along the bottom of the screen and when I looked at the sides there appear to be no gate drivers on the left and right sides of the TV. So I am going to focus on the left side of the panel first since I think that is the side that is affected.
