Evga Gtx 980 ti black screen
    Hello
    I bougt a Evga gtx 980 ti that had a shorted drmos, after I change it the card boots up and works fine intil i start a game(heavy load) then it crash and reboots.
    The voltage is stabil on vcore, se attachments.
    I have pwm pulse on all inductors.
    Shuld i also change the driver (ncp81162)?
    Can sombody help here??
    Re: Evga Gtx 980 ti black screen
    Try to clean pcb and apply new thermal paste the graphics chip.
      Originally posted by tohetlan View Post
      Hello
      If you lower the power limit to 80% does it still blackscreen?
        I have tried to change thermal paste, clean the pcb with alcohol and lower power limit to 80%, Nothing helps?
          Did somebody experience this problem with faulty memory?
          I am open for anny suggestion!!
            As it's partially working, why don't you test the memory to rule that out?
              Does sombody have a program to test memory (mat og mods)?
                First try to reprogram the bios then,I think you should replace the v core ic and upgrade the mosfets to a higher current ones.
                  Ok, thanks.
                    Hello
                    I have the same problem as you but it crashes in game and displays a black screen when launching a game but not in desktop.
                    Here is my post from a few days ago.
                    https://www.badcaps.net/forum/showth...42#post1159142
                    You can try with the LORD OF GPU software but you'll need a decent hard disk about
