Hp 15n da0u81mb6c0 laptop no display
    Dear Friends
    am having hp 15N with DA0U81MB6C0 motherboard which is not working.
    Laptop is powering on and fans are running. but no display,
    please tell me the voltage points to check and troubleshoot
    Thank you
    Re: Hp 15n da0u81mb6c0 laptop no display
    Check voltages on Coils ( Gray square components ) around CPU.
      Yes
      PL13-1.1v
      PL14- No voltage
        I suspect PU4 or PU3 or both. So check voltages according with Schematic.
          Bro try bios only........
            Hi bro
            Am using MINIPRO TL866a programmer, Unable to flash the bios or read the bios. is it compatiable or i have to use another programmer.
            If yes please suggest me a good programmer.
              Dear Raajkumar,
              I will check the both PU3 & PU4 and let you know
                Originally posted by sureshbobby View Post
                Hi bro
                Bro i'm using EZP2010
                  Hi Bro My motherboard model is DA0U81MB6C0
                  QUANTA U81
                    flash bios .check blinking in k/b
                      Hi Udai,
                      Thank you. but i was unable to flash bios with my Bios programmer TL866A
                      will you guide me
                        check whether its a 1.8v chip. If so, you will require 1.8v adapter
                          I cannot program both main and ec bios, Please suggest me
                            Same problem to me also.Both bios flashed.but no vcore coming.1 caps lock blinking
                              Missing S0 rail and/or ALL_SYS_PWRGD maybe.
                                Hi, Same board,DA0U81MB6C0 with graphic -no display.
                                Found U24 Audio and U9 Lan chip heating removed both , but still no display.
                                U23 Intel seems heating bit more along with heat-sink around 50-55 max. Should i replace intel.
                                power at coils seems normal.PL13 1.1volt .no 0 volt at PL14.
                                Looking for bios with graphics. felt webcam also heating.
                                Please Guide me.
                                  Very likely a shorted pch on usb section. check reistance on D+/D- on usb port.
                                    Thanks i will check and update
                                      Cheaked D+/D- showing 5.5 to 5.9 Meg-ohms .
                                        Audio/Lan/Webcam -all controlled by PCH. So i doubt some damage to PCH itself. USB resistance is fine though. PIN3 of PU4?? Disconnect webcam and try to boot. Is there display?
