What sort of capacitors are these?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Guys, what sort are these - so I can order some replacements
    They are through hole not SMD. Also how do I read the markings on this type to determine the voltage.
    I take it the 270 = 270uF
    Follow me on YouTube
    Learn Electronics Repair
  • diif
    • Feb 2014
    • 6978
    • England
    Re: What sort of capacitors are these?
    Nichicon PLF I think.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      • stellaa9x
        • Sep 2020
        • korean
        Nichicon PLF
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          270uF, 16V
          PeteS in CA
          • dragon3x
            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
            by dragon3x
            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
            power on.
            Here are some examples :
            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
            switching supply area).
            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
            than 6.3 V.)
            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
            I replaced capacitors with aluminum-polymer.
            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
            03-21-2025, 02:46 PM
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
          • Ady2017
            Are there any datasheets available for Elna RJG capacitors?
            by Ady2017
            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
            05-25-2025, 02:19 PM
          • ctroxtell
            Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
            by ctroxtell
            I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
            01-03-2025, 08:57 PM
