Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 12-04-2019, 01:45 AM   #1
Bloopeta
City & State: Hartlepool
My Country: United Kingdom
I'm a: Knowledge Seeker
Default Panasonic TX-55CX400B backlights flashing on and off
Hi peeps, have a Panasonic TX-55CX400B here, guy I got it from said he tried to turn it on other day, and no backlights.
When I received it last night, I plugged it in, and it came straight on and appeared to be working fine, so knowing this would only be temporary, I left it running for a good few hours, and they eventually went off. I tried turning it off and back on again, and this time the backlights started flashing at a steady continuous pace. So I turned it off and left it overnight as it was getting late.
This morning when I turned it on, same problem, backlights flashing, so I stripped it down and tested the LEDs and 1 was dead. So changed the dead LED, thinking that would solve the problem, but it hasnt.
So now even with the bad LED replaced, turn it on, and backlights flash in a constant uniform manor, only difference now is, they are all illuminated. Also you can hear a noise from the powerboard, that runs in time with backlights flashing. However if I unplug the backlights from the powerboard, and switch on, this doesnt happen, it comes on and holds steady.
Ive included a pic of underside of PCB, cant see any dry joints etc, but I have included a close up of a section of the board that caught my eye, just would like peoples opinions on that section please?
Anyone came accross this before? Or could point me in the direction of where to start with diagnostics now please?
Bloopeta is offline   Reply With Quote
Old 12-04-2019, 06:10 AM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Panasonic TX-55CX400B backlights flashing on and off
The joints in the R551 area look a little funky??
nomoresonys is offline   Reply With Quote
Old 12-04-2019, 06:14 AM   #3
nomoresonys
My Country: U.S.
That cap by C514 looks a little suspicious.
Old 12-04-2019, 06:24 AM   #4
nomoresonys
My Country: U.S.
Check all your diodes.
Old 12-04-2019, 11:12 AM   #5
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Do you have backlight tester?
If you do, what is the Vf of each LED string?
BTW, the bad LED, was it shorted or open?
__________________
budm is offline   Reply With Quote
Old 12-04-2019, 12:51 PM   #6
Bloopeta
Ive ordered one a couple of weeks ago, bit still hasnt arrived yet
And the bad LED was shorted
Old 12-04-2019, 12:53 PM   #7
Bloopeta
Quote:
Ive tested all diodes with DMM, and this one D516 is raising suspicion, on diode test mode its reading 020 both ways :/ and beeping both ways.
Old 12-04-2019, 12:58 PM   #8
budm
budm's Avatar
My Country: USA
Cane we see the bottom side of the board so we can see how that diode is connected in the circuit.
Try lifting one leg off the board and re-test the diode.
Old 12-04-2019, 01:04 PM   #9
Bloopeta
Here are the pics, ill lift a leg and retest and report back
Old 12-04-2019, 01:20 PM   #10
budm
budm's Avatar
My Country: USA
That diode is part of RCD (Resistor/Capacitor/Diode) Snubber network.
The solder joint on the leg of the cap that is connected to the Cathode of that diode D516 has ring around the joint, that should be re-soldered, look at other solder joints as well for that kind ring forming on component legs.
Old 12-04-2019, 03:21 PM   #11
Bloopeta
I have lifted 1 leg of said diode, and getting the same reading as before, 020 and beeping both ways. So that will need replacing?
Old 12-04-2019, 05:29 PM   #12
budm
budm's Avatar
My Country: USA
What are the numbers printed on it?
Old 12-04-2019, 05:39 PM   #13
Bloopeta
HER207
I have replaced it, resoldered the area you pointes out, and went over board and touch up any points that looked remotely like needed it, and hey presto, we have functioning backlights! Gonna leave it now as its 23.27pm here, and ill get it all resembled in the moring.
Old 04-25-2020, 11:55 AM   #14
sordids999
sordids999's Avatar
City & State: United Kingdom
My Country: uk
Line Voltage: 240v
I'm a: Hobbyist Tech
Backlights working but sometimes the backlight will go off
17ips20 low voltages across most caps
Led voltages upon turning on the tv will jump to 155 volts but does not drop
Led - 10v led + 155v led - 10v led + 155v
Any help please
sordids999 is offline   Reply With Quote
Old 04-25-2020, 11:59 AM   #15
sordids999
sordids999's Avatar
My Country: uk
Line Voltage: 240v
Pictures of the psu
Old 04-25-2020, 12:05 PM   #16
sordids999
sordids999's Avatar
My Country: uk
Line Voltage: 240v
Sorry hopefully better pictures
Old 04-25-2020, 12:20 PM   #17
neilc6
City & State: BC
My Country: Canada
Possibly an intermittent LED in the backlight. Did you try turning down the backlight level? Not sure if that model has local dimming as well.
neilc6 is offline   Reply With Quote
Old 04-26-2020, 02:34 AM   #18
sordids999
sordids999's Avatar
My Country: uk
Line Voltage: 240v
The strange part is if I swap the 17ips20 which as you can see in the picture has taken alot of heat in the top right with another 17ips20 but slightly different I'm now getting a dark patch in the middle of the screen so its possibly pointing to a bad led inside the screen
It's a shame because I cant find any new sets of these leds anywhere
Old 05-13-2020, 01:43 PM   #19
Judderz
City & State: Dorset
My Country: Uk
Hi guys sorry jump on this thread but it's the only one with my TV
(Tx-55cx400b)
I'm waiting for a few bits to arrive to test properly, the screen was blank so I've done the strip down and checked and I have 3leds out (fingers crossed that is the only fault)
But whilst I'm waiting for items to arrive I've just remembered that some of the spacers/risers/standoffs where brittle and broke so I'm now looking for those, but what the 🤬 are they called🤔 (see pic) please help me.....
Judderz is offline   Reply With Quote
Old 05-13-2020, 09:49 PM   #20
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Where have they broken ? If its just the attaching lugs i just use dab of hot glue for sticking them down.
diif is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
