Anyone recognize this power supply?
    Its 13.8v and unknown amps, 100?
    There is no name and it has 5 identical modules in it.
    Dont know where else to ask.
    thanks
    Re: Anyone recognize this power supply?
    It could be a forklift battery charger would be a good guess
    But very old model is my guess
    I would test each module by it self just make sure pay attention to how it is hook each other
    I would expect that to start the charging cycle you probably have at least a minimum of 8 to 10 for it to start charging would be my guess
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      not a forklift, the cells are in series - 48v or higher.
      it could be an early solid-state charger for garages though.
        It might be from a audio display system used in stores.
          Naw... doesn't have big enough filter caps. Looks like it used to run a lot and someone knew how to fix it (a lot). The screw holes are worn, extra grounding lug...
          My guess, a commercial PSU, ran something in some sort of an transmitter site. Second thought: An shore charger for the battery bank on a boat?
            Any printing on the circuit boards at all?
              I think I saw a 1989 date code on that silver-colored 85C 1000uF made by El Cap.
              PeteS in CA
                strange coil on the output . and what looks like a motor cap .
