Microsoft Surface Book (1703) password
    Here is a bios dump i have tried to crack but no luck, if any one here can try.
    Last edited by SMDFlea; 10-03-2023, 01:49 PM. Reason: Renamed thread title, there is no model 3 1703
    Re: Microsoft Surface Book 3 (1703)
    Here you go.
      Originally posted by RethoricalCheese View Post
      Here you go.
      Hi
      Thanks i am surprised only 1 byte of change made difference, it did some changes in bios setup but one issue i cant change UEFI Passwors it states above "Some settings are managed by your organization" in security tab.
      you have any solution for this ?
          try this
          and.. goodluck
            Originally posted by rioreno View Post
            try this
            and.. goodluck
            Thanks a lot it worked and RethoricalCheese
              Surface 1703 is original surface book model .. why you are saying this is surface book 3?
              can you please confirm?
                How you get bios dump?
                  you will need an SPI programmer...
                  https://www.youtube.com/watch?v=DWWigscuQDY
                    That mean without opening laptop can't get bios dump from Surface Book?
                    And open laptop without damaged screen can't
                      Microsoft Surface Book 3 UEFI locked (AMITSESetup missing)
                      Hello.
                      I have completely locked 15" Microsoft Surface Book 3 (windows password, UEFI password + USB boot disabled). So I dissasembled it, desoldered Winbond W25R128JW NOR flash, read it with CH341 (with 1.8V converter) and now I am trying to find encrypted password (with UEFITool / HxD). But there is no patterns like this:
                      65 74 75 70 00 (AMITSESetup.)
                      01 4E 56 41 52 (.NVAR)
                      I am confused... Is there some kind of new protection mechanism?
                      Can you please give me some advice how to proceed?
                      Thanks!
                        Re: Microsoft Surface Book 3 UEFI locked (AMITSESetup missing)
                        Originally posted by parezj View Post
                        Hello.
                        Thanks!
                        probably the programmer read it with errors.. use these programs for CH341A...
                        https://www.badcaps.net/forum/showpo...6&postcount=10
                        https://www.badcaps.net/forum/showpo...04&postcount=7
                          Surface book 1703 Bios password
                          Have an Surface book 1703 with Bios password locked, is there any way to decrypt the pass instead of unlock it?
                          Bios dump :
                            Re: Surface book 1703 Bios password
                            Bios dump :
                            test and comment
                              Re: Microsoft Surface Book 3 (1703) password
                              Bios lock is gone, but there is also an "SEMM" lock. I asume that from this surface model reading(decrypting) bios password is impossible?
                                Hello guys! Need some help removing the bios password on this Surface Book 1 (1703). I have attached the old dump. By the way, did anyone have issues with sound and cameras not working due to a bios setting on this model? Thanks in advance!
                                  try.
                                    try.
                                    Worked like a charm. Multumesc!
                                      Hi.
                                      Yes, you are right. NV bios area is all FF. After some time I am pretty sure that it is because RPMC (Replay Protection Monotonic Counter). It is new NOR flash W25R128JW and if I understood it well, there is saved HMAC SHA-256 security key inside the NOR flash. Without knowing it, and without executing "Increment Monotonic Counter" instruction, the protected area cannot be accessed.
                                      How can I read this stupid chip please W25R128JW?
