pls help samsung R730 short
    hi everyone
    samsung R730 BREMEN-L3 1.1 091224-3
    first the laptop was dead no power no led
    i found a short , i replace the Q22 the laptop power on but ALL led's is on and the consumption of ampere is very high 4A and all power mosphets become very hot .
    i found 9 ohm on L 13 and 13 ohm on L8 is it short or not ?.
    what is the short source .
    i need the schematic for this laptop
    i found one but it is different
    Re: pls help samsung R730 short
    Can you tell us to which signal represents on L13/L8. If thet are on cpu/gpu lines, it may show low resistance.
      Use schematic from bremen-ul for reference - https://www.badcaps.net/forum/showthread.php?p=965473
        L13 for chipset .
          it's wrong schematic ; everything is different .
            L8 for chipset POWER (1.05v) .
              Q22 and is UGTA for U513 and L8 is output coil
              U513 (51117 ic) generate 1.05
              L8 VOLTAGE =0.16v
              u513 has the en signal on pin 1 and vcc on pin 4 but no outupt voltage .
              i think it's time to replace u513 .
                any help ?
