Power supply build quality pictorial DISCUSSION
This is a sticky topic.
  • Newbie2
    • Sep 2005
    • 885
    Re: Power supply build quality pictorial DISCUSSION
    Originally posted by japlytic
    In the L&C LC-B450E 450W supply, the 330uF 200V primary capacitors are inadequate for a supply of this size.
    And those primary capacitors are also generic (has some logo that is the planet saturn) caps.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #42
      In the L&C LC-B450E 450W supply, the 330uF 200V primary capacitors are inadequate for a supply of this size. They should be at least 680uF.
      Please explain why, I live to learn
      From this thread: https://www.badcaps.net/forum/showthread.php?t=1202
      Can someone more knowledgeable than me please comment on the very small rating of the Primary bulk cap, only 270uF, and 220uF in the 350w Seasonic?
      Is it due to the active PFC or something? I mean I've seen Primary caps in L&C powersupplies with almost twice the farad rating!!!
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        #43
        New Dell Server PowerEdge 2800 which has 2x2.8Ghz dual core Xeons has PSU 930W!
        • gg1978
          • Dec 2004
          • 431
          Well, i was going to post pics of my Delta DPS 300BB, but it looks like larrymoencurly already has.. I bought a pair of them back when directron.com had them for $13 each.. I wish i would have bought at least 6 more of them..
          They are perfect for running AMD socket A systems that are demanding of +5V and +3.3V. I've got one in my HTPC as a matter of fact, although it would probably work fine with a 250W PSU, i want that little HTPC to live a long and happy life, so it gets a server grade 300W Delta.
          It's probably the best built PSU i've seen, when it comes to heatsinks, tons of toroids, and good quality capacitors. If only the 300BB had a +12V P4 connector, it would be powering my Athlon 64 also..
          On the label, it says that you can have 245W max between the +3.3 and +5. I wish Delta would sell their stuff to end users. I'd love a 400W PCIexpress compliant one..
          • larrymoencurly
            • Oct 2004
            • 960
            Do you mean you haven't added the connector to it? There's an unused hole in the circuit board for the pair of +12V wires, but for the ground wires I had to drill a hole really close to a capacitor. Sure, this PSU is rated for only 13.5A @ +12V, but they're honest amps.
            • BluBlur
              • May 2005
              • 45
              #46
              I have a question. There are always very low capacitance (2.2 to 10uf), medium volted (25-50v) caps on PSUs. Some are found beside transformers, some near coils, etc. Should these caps remain during recapping, as some are hard to reach?
              • Newbie2
                • Sep 2005
                • 885
                These very little caps should be left alone since 470uf or 1000uf or more caps are affected. The very little caps aren't affected.
                My gaming PC:
                • larrymoencurly
                  • Oct 2004
                  • 960
                  A bad Jamicon 1uF cap in my TV caused the picture to stretch at the bottom part. And several years ago, my then-fairly new cheapo PSU, maybe a Deer, a 1uF, 16V cap shorted, and after replacing it I borrowed my friend's scope and saw 50V spikes across it and a few other 16V caps.
                  • linuxguru
                    • Apr 2005
                    • 1564
                    #49
                    You can leave most of the small caps alone, barring a few related to the ATX auxiliary supply, which generates +5VSB. There's a primary side flyback cap there that fails often - check the thread on Eurocase PSUs for more details.
                    • Newbie2
                      • Sep 2005
                      • 885
                      Originally posted by dood
                      Thermaltake PUREPOWER-480AD ATX12V PSU
                      Fancy brushed aluminum plate... functionality? Guess again...
                      Teapo main caps...
                      And teapos on the other side too...
                      This PSU has not been used yet, so unsure of its reliability. I'd guess it's not too bad. Comes with a PCI plate or 5 1/4" drive bay filler for a fan speed knob, i think.
                      I think that was made by High Power, their HPC-480-102DF power supply has the same dual orange 80MM fans, black casing, and even the same amp ratings.
                      http://www.highpowersupply.com/produ...c480102df.html
                      High Power HPC-480-102DF
                      Dood's ThermalTake
                      My gaming PC:
                      • Newbie2
                        • Sep 2005
                        • 885
                        Originally posted by kc8adu
                        powmax redundant.
                        note the burst cap in lower right.note the engrish on the label!
                        this is on +5stby.
                        this unit was in a hot spare server plugged in but not running.
                        if it were run any at all all the caps would have likely failed.
                        That Powmax redundant power supply has been known to give out a small puff of smoke, but work okay after the first turn-on.
                        My gaming PC:
                        • Newbie2
                          • Sep 2005
                          • 885
                          okia 450w
                          A search of the UL file number for that power supply (E194657) shows that the company is BROADWAY COM CORP, which is actually in the USA!
                          BROADWAY COM CORP
                          19715 E HARRISON AVE
                          CITY OF INDUSTRY, CA 91789 USA
                          TigerDirect sells an Okia 450W and it got 4 good reviews. On TigerDirect right now it is the 2nd best seller and it is usally the 4th or 3rd best seller on the best seller list for power supplies on TigerDirect.
                          http://www.tigerdirect.com/applicati...ab=11&NoMapp=0
                          http://www.tigerdirect.com/applicati....asp?CatId=106
                          that okia unit was in a p4 2.8 with 6 hdd,2 opticals and lots of lights.
                          +5 was running 4.35!
                          it got hot enough to stink.
                          got a worse one than that to post later!
                          Where did you get that 4.35V reading on the +5V rail?
                          Did you use the motherboard voltage monitoring or did you use something that has more accurate readings?
                          My gaming PC:
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            #53
                            BROADWAY COM CORP
                            read from a drive cable with a fluke 77
                            and good reviews cant change the crap i see in this one!
                            and us oldtimers call them tigerdefect :-)
                            those reviews were likely posted by a shill.
                            and remember the cheapest is usually the best seller .
                            • PeteS in CA
                              • Aug 2005
                              • 3578
                              • USA, Unsure of Planet
                              #54
                              Looks like Broadway Com Corp is an importer. Now, if you want to build a computer while on a backpacking trip, they might have everything you need.
                              PeteS in CA
                              • tylerlough
                                • Dec 2005
                                • 96
                                #55
                                Originally posted by Chris1992
                                I have the same PSU, Tyler, it's a Dell/Lite-On unit. They sneezed all over the inside of the PSU.
                                That snot is better than a noisy singing PSU.
                                Must have been done by a girl because guys can aim.
                                • japlytic
                                  • Oct 2005
                                  • 2086
                                  Pictures of the FSP235-60GT are found on https://www.badcaps.net/forum/showth...ht=fsp235-60gt
                                  Mine was built in 1998, and had smaller heatsinks than the ones in the link. It also had some "WC" brand capcitors, as seen on https://www.badcaps.net/forum/showth...3126#post13126
                                  The first filtering capacitors for the +5V and +3.3V rails were Fuhjyyu TMR Series (3300uF 10V), with the output capacitors being Fuhjyyu TNR Series (4700uF 10V TNR for +3.3V; 3300uF 10V TNR for +5V). There was one "WC" branded capacitor (1000uF 16V) on the +12V rail - a bit inadequate.
                                  • larrymoencurly
                                    • Oct 2004
                                    • 960
                                    Should I be worried about this PSU found inside my external drive enclosure?
                                    https://www.badcaps.net/forum/showth...3626#post13626
                                    It's not UL approved, and there's no room to add a line filter because the circuit board normally sits right next to the AC receptacle. Also the plastic sleeving of the black/gold cap at the far right was melted in a few places, and its leads had a big solder bridge between them -- on the top side of the PC board.
                                    OTOH the USB-IDE controller is based on an NEC chip
                                    • Rainbow
                                      • Aug 2005
                                      • 1371
                                      #58
                                      Looks like total POS.
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        #59
                                        those green caps are Koshin brand.
                                        • japlytic
                                          • Oct 2005
                                          • 2086
                                          That power supply looks like junk to me - the manufacturer had cut quite a few corners in it. There is also a Fcon capacitor in it as well. If there are no specifications on the supply, I recommend a good supply with 2A output each on 5V and 12V.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • CMCM
                                            Russound CA4 Power Supply Repair
                                            by CMCM
                                            Hello Everybody,
                                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                            The outputs marked 12v and 20v are all measuring only 1v.
                                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                            The capacitors physically look clean (no bludgesor leaks) and...
                                            07-03-2025, 01:12 PM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            06-23-2025, 04:38 PM
