Need Panasonic FZ-G1 Bios DFUP2371ZE
    Hi Friends ,
    need unlocked bios dump of Panasonic FZ-G1 : DFUP2371ZE
    or if someone can unlock original file attached,
    THANX
    Re: Need Panasonic FZ-G1 Bios DFUP2371ZE
    bismillah
    There are 10 types of people in the world. Those that understand binary and those that don't.
      Originally posted by eikspaj View Post
      bismillah
      baraka allahou fik
      thanx for all brother
      i'll reply after testing
        Hi Friends ,
        Need unlocked bios dump of Panasonic DFUP2371ZE
        Thanks.
          bismillah
          Work perfectly, thanx a lot
            Originally posted by Sashajkl View Post
            Hi Friends ,
            Thanks.
            try this FZ-G1-2
            goodluck and please confirm
              Originally posted by rioreno View Post
              try this FZ-G1-2
              Hi. Fine. Thank. Check it out.
                try this FZ-G1-2
                Hi. Thank you for your work. It seems to me that this does not work properly because I did not correctly read the original bios dump.
                  Is it possible to take bios from the second post and put it on my laptop?
                    okay , try this,,,
                    i was rebuild from your old bios (Descriptor,ME,Gbe region), and bios region from extracted update panasonic
                    BIOS_G1_V201L19.EXE
                    injected your SN,Model,Winkey from your bios..
                    goodluck
                      okay , try this,,,
                      BIOS_G1_V201L19.EXE
                      goodluck
                      Thank you for your high desire to help. It does not turn on. Only the indicator on the tablet flashes once every 2 seconds
                      Maybe try to take bios from the second post and insert my data there?
                        okay , try this,,,
                        BIOS_G1_V201L19.EXE
                        goodluck
                        I have a ch341a programmer. Previously, they were flashing other laptops and everything was fine. Firmware version CH341A Programmer
                        1.34. I evaporate the chips before the firmware. When checking the buffer, it throws an error on FZ-G1. There is also a program NeoProgrammer 2.1.0.16. In it, a buffer check passes. I was stitching the latest dumps of this tablet with it. But the tablet has a black screen. Only indicators work. Maybe there is a problem with my programmator?
                          okay , try this,,,
                          BIOS_G1_V201L19.EXE
                          goodluck
                          v201l19.exe This bios is slightly different from this model. One letter is another. Please try to edit the attached bios. This one is definitely mine.
                            okay , try this,,,
                            BIOS_G1_V201L19.EXE
                            goodluck
                            Tomorrow I will receive an adapter for 1.8v flash bios for my programmer. And try flashing it again with your bios.
                              I think the problem is either in the programmer or in the program. I soldered the Bios chip. The program erases, checks for a dummy, writes. But when it comes to checking, the program says that the buffer does not match. That was all my attempts.
                                Hi. I think the problem is in my programmer. This week I plan to purchase ezp2010.
                                  what model your ch341a ? black? there s 2version 3 and 5 v...
                                  and have you try other software? like asprogrammer
                                    Hi. Thank you for helping me all this time. I do not know the version of my ch341a programmer. But I took a photo on both sides.
                                      Hi. Today I purchased the ezp2010 programmator. From the first time it turned out to flash your last Bios. The one that has the title "New". This miracle finally happened. I am very grateful to you. Without you, I would not have succeeded. 😄😄😄👍👍👍
                                        One driver throws an error. Also, because of this error, it does not allow updating bios through windows
