PLEASE NEED BIOS AN EC ASUS GL503V MAIN dabklmb1aa0
  • aldopc
    • Jul 2017
    • 464
    • Chilito
    Hello friends someone help me, I need bios and ec asus GL503V the owner says that I took it to Asus because I turned off the equipment in the middle of an automatic update of the bios since or knew what it was, when checking it I see that there is a chip that it is not the original one they put a bigger one where the ec goes, the query is can you use another chip different from the one that originally came? the equipment does not give an image they only turn on the keyboard lights nothing overheats attached images ...
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: PLEASE NEED BIOS AN EC ASUS GL503V MAIN dabklmb1aa0
    post your backup bios
    • aldopc
      • Jul 2017
      • 464
      • Chilito
      Hello Claudio, do you speak Spanish or English? this is the file
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        Originally posted by aldopc
        Hola Claudio hablas español o english ? este es el file
        Si hablo español, português e english.
        This is your file repaired.
        Try and report..
        Este es tu archivo reparado.
        intenta e informa..
        • aldopc
          • Jul 2017
          • 464
          • Chilito
          Try and report..
          intenta e informa..
          No funciona Claudio me parece que el problema esta en el chip ec ya que lo reemplazaron y colocaron otro chip winbond de otro tipo y voltage me parece que es ese el problema arriba puse imagenes... lamentablemente no tengo ningun chip de ese tipo (25q40ewnig) crees que sea ese el problema?
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            Please write in english or otherwise you will be warned for that. This is an english forum. Use google translate if you need.
            The ec chip replaced are the same specs? It´s a new (blank) chip or used from other laptop?
            This chip "25q40ewnig" maybe it´s a VGA bios (your laptop have a gtx1060).
            EC chip is the ITE SIO
            I attached the EC file for your laptop.
            • aldopc
              • Jul 2017
              • 464
              • Chilito
              Ok, I understand I thought I could write you in Spanish, No it does not have the same specifications so I put the images so the team arrived, instead of arriving with the 25q40ewnig chip someone removed it and put a larger chip as I showed in the images. .. and I don't have a 25q40ewnig chip, I thought that the ec was that chip (25q40ewnig) but you tell me that it is the vga chip that gives meaning to the failure, but I don't have an identical chip to write this chip .. .
              • Claudiomfa
                • Nov 2015
                • 455
                • Portugal
                This chip that you talking, they don't be the same as original. It can be larger or other manufacturer, but need to have same specs as original.
                Post backup from this chip if you can.
                • aldopc
                  • Jul 2017
                  • 464
                  • Chilito
                  Ok, Claudio thank you very much I appreciate your help, finally I ordered the chip on aliexpress here in my country I could not find it so I will wait for it to arrive, do you have the firmware of the graphics card that goes on this chip or do you know where to get it?
                  • Claudiomfa
                    • Nov 2015
                    • 455
                    • Portugal
                    I don´t have this firmware. If it's realy nvidia graphics bios, I think the only way is backup from another laptop. Perhaps anyone on this forum could have.
                    • aldopc
                      • Jul 2017
                      • 464
                      • Chilito
                      Ok, friend, I already solved this problem, your repaired file works perfectly, finally I bought the vga bios chip on aliexpress, and I found the firmware of the NVidia GeForce GTX 1060 6GB, in another forum, I programmed it and finally it went on and it was ok, I will leave the file here in this thread, this file was from an asus GL703GE, and it worked on my GL503V. note this file is from the graphics card (GTX 1060 6GB)
                      • Albertoq
                        • Jul 2019
                        • 11
                        • Perú
                        Gracias por el aporte de la Nvidia
                        Thanks for the input from Nvidia
                        • stevetaylor
                          • Sep 2015
                          • 42
                          • romania
                          TRY THIS, Clear me configured
                          • stevetaylor
                            • Sep 2015
                            • 42
                            • romania
                            working for me,fast boot
                            • stevetaylor
                              • Sep 2015
                              • 42
                              • romania
                              sorry, I forgot to put 0 in the middle
                              • itya
                                • Jan 2023
                                • 3
                                • slovakia
                                how you prgram that chip i got same modelwhen press power keyboard light comes on red then green then blus then off again press power same but my board doent have any bios for graphic i guess
                                • aldopc
                                  • Jul 2017
                                  • 464
                                  • Chilito
                                  Hello, mine was a special case, someone had removed the original chip from the bios of the graphics card... you must reprogram the bios with a functional file, first you must identify the exact model of your motherboard and look for the file.
                                  • razor_amd
                                    [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                    by razor_amd
                                    With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                    For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                    I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                    This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                    12-15-2020, 07:07 PM
                                  • throwaway327
                                    Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                    by throwaway327
                                    ASUS ROG Ally X - (Handheld Gaming PC)
                                    Model No: RC72LA
                                    Serial No: SBNVKD001014459
                                    Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                    I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                    06-18-2025, 05:52 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • lrouw84
                                    Asus vivobook s510ua bios changed to x510un
                                    by lrouw84
                                    Hi there,
                                    I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                    I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                    01-28-2023, 01:31 PM
                                  • robgerr
                                    Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
                                    by robgerr
                                    Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
                                    Attach...
                                    11-17-2023, 09:52 AM
