Old 04-19-2020, 05:12 PM   #1
Roli
Default Acer 8943g shorted motherboard with LVDS connector
Hello , so i forgot that my laptop had a battery in it ... and plugged in the lvds connector to the display, yes i know stupid , and then i smelled something burning , so when i started up the laptop i had a white screen , and after that not even a white screen anymore , it is black , no backlight and also no image , the vga port works fine , the laptop boots .
I tried with a flashlight to see if there is image ,but no image.
There was a small smd on the motherboard marked as : L43 , it was burned i changed it , but i still dont have any image , only on vga.
And no the motherboard has no fuses near the Lvds, so maybe someone has a better ideea ?
I have some images of the board and what i changed .
Thankyou !
Roli is offline   Reply With Quote
Old 04-20-2020, 04:42 AM   #2
Roli
Default Re: Acer 8943g shorted motherboard with LVDS connector
Nobody any ideea ?
Old 04-21-2020, 05:19 AM   #3
lapfix
City & State: my house
My Country: my workshop
Make sure that your problem is NOT on LVDS cable or LED panel.change them and see if your issue is gone
lapfix is offline   Reply With Quote
Old 04-21-2020, 04:54 PM   #4
Roli
Thanks for replying , ive checked the lvds , its okay, but i managed to find an acer 15.6 inch display with same 40 pin connector and gues what , the display turned on perfectly , so now i know the motherboard is okay , lvds ok , all compoennts okay ,except the display
The display board failed on the display , but again i dont see anything burnd or suspicious , so i think there is a short somewhere and cuts off the whole display , so it wont turn on , i see some test points on the displays board :
LED_PWM
LED_EN
EE_VDD
SC
SD
GND1
N-WE
Maybe someone repaird laptop display boards and can lead me further ?
Old 04-21-2020, 05:28 PM   #5
Roli
Ok so after a better examination i have found the problem ( posible problem ) , found a burned resistor , but the problem is i cannot see the value of it , i cannot read the middle of what it says on the resistor , only the left and right side but not the middle , ive made a picture .
It writes E E , left and right side , but cannot determin on middle , now what should i do ?
Old 04-21-2020, 11:59 PM   #6
khaahk
khaahk's Avatar
City & State: Tallinn
My Country: Estonia
Look where the resistor is connected to. Zoomed out picture might be helpful. The planes that the resistor is connected to seem big, also there is a conductive tape on one of the planes, usually these are put on GND planes.
Might be 3R3 resistor acting as current limiter.
Not sure - so do not act on this suggestion.
khaahk is offline   Reply With Quote
Old 04-22-2020, 02:19 AM   #7
lapfix
Perfect , you can easy guess the resistor value , any 15.6 inch display / 40 pin connector can give you an idea .
Old 04-22-2020, 09:02 AM   #8
Roli
Ok i managed to change the resistor , the display still wont start , ive managed check an IC marked as : S24C02 , its a 2Wire serial eeprom , donno why but its verry hot , and its shorted to ground ...
I think i am going to remove that and check if it works maybe without , but i dont think so ...
Old 04-22-2020, 09:24 AM   #9
SMDFlea
Moderator
City & State: York
My Country: UK
The S24C02 is the EDID eeprom. You`ll need to program a new chip. What part number is the panel ,post a picture.
SMDFlea is offline   Reply With Quote
Old 04-22-2020, 05:34 PM   #10
Roli
The model number is N184H6 - L02 Rev.C1 , posted picture .
So basically i need to order a new chip and reprogram - it ?
If yes i have only 1 programmer , TL866 , need to check if it supports this chip ...
Or are there any other ways to program this ? Maybe using paralel port or serial port ?
And where can i get firmware for this ?
Old 04-23-2020, 03:35 AM   #11
SMDFlea
Moderator
City & State: York
My Country: UK
I posted the bin in the LCD EDID dump thread, post #42 . https://www.badcaps.net/forum/showthread.php?p=957055
If you don`t have an adapter for the tl866 you could use an old lvds cable to flash it (post #6). Any 24C02 chip will do from an old panel, RAM ,HDD,scrap pcb .
Old 04-23-2020, 04:41 AM   #12
Roli
Wow thanks for the quick reply , i will try to find a good chip , hopefully today !
Old 04-23-2020, 12:53 PM   #13
Roli
Ok so i managed to program the new ic with the file you provided, the display turns on but its only white .
Old 04-23-2020, 12:55 PM   #14
Roli
Ok what i found just now that there is another ic that is getting verry verry hot , the writing on the ic is : CW=BJ 12R , i cannot find anything about this ic , what is this and where can i get one ?
Posted picture of the ic .
Old 04-23-2020, 01:23 PM   #15
SMDFlea
Moderator
City & State: York
My Country: UK
Its a Richtek RT9921CGQV .https://www.richtek.com/assets/produ.../DS9921-04.pdf
Old 04-23-2020, 03:57 PM   #16
Roli
I found a similar chip , posted picture , is that the same thing is it okay to change it ?
Old 04-23-2020, 05:55 PM   #17
Roli
Nevermind that is an LED driver i think ...
Old 04-23-2020, 06:02 PM   #18
Roli
I will have to order it from china , it will take like 2 months because i dont have one , on this N184H6 display , there is another ic , it is not hot or anything , but im afraid if i order the RT9921 and change it , maybe this other ic will be hot to and i want to order that also because i dont want surprises , so on the other ic it writes DW=BK W16 , what ic is this ?
Attached a picture
Old 04-24-2020, 04:11 AM   #19
SMDFlea
Moderator
City & State: York
My Country: UK
It could be a Richtek RT8562BGQW DW=xx
https://www.ebay.com/itm/3pcs-RT8562...-/401680959547
EDIT: Datasheet https://www.richtek.com/assets/produ...DS8562B-06.pdf
Old 04-24-2020, 08:29 AM   #20
Roli
You have been verry helpfull , thankyou ! , and about that 2 ic-s that i need , are those available only in display's or can you find them maybe on laptop motherboards or something ?
