Westinghouse WD32HB1120
  • digitalscorpion
    • Mar 2012
    • 37
    See pics. Screen shows only that. Power supply is fine. Voltages show up all across the integrated Tcon. Panel ribbons seem bonded fine. no components getting hot.
    I have 2 of these, same model, other one image is fine (shows complete display but white washed). Just chalk it up to bad panels with this model?
    Re: Westinghouse WD32HB1120
    https://www.badcaps.net/forum/attach...7&d=1589486583
    Can we see larger pictures showing all the brown flex PCB between LCD glass (you show only two) and the integrated T-CON board? Do they all look OK?
    • R_J
      • Jun 2012
      • 9535
      When I see this it usually means someone cleaned the screen and the liquid ran down and damaged the panel..
      • digitalscorpion
        • Mar 2012
        • 37
        I will need to open it again, but they did look like the same as the 2 shown. Didn't appear separated. I put light pressure on them while watching the screen, no change. Is that where I should be focusing?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8084
          one has a tab bond problem or a damaged panel and the other (white wash) a tcon problem.
          • mecha1166
            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
            by mecha1166
            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
            11-25-2024, 05:22 PM
          • CapLeaker
            Dell ATX PSU won’t start, but forcing it works fine?
            by CapLeaker
            Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
            Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
            10-28-2024, 06:59 PM
          • emil_t
            RTX3090 working fine but fans not spinning
            by emil_t
            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
            04-12-2024, 06:54 AM
          • Grouickman
            Hofmann geodyna 6300 Wheel balancer
            by Grouickman
            Hi there,
            First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
            Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
            I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
            I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
            03-31-2025, 05:29 AM
          • Rauni
            Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
            by Rauni
            Hello, this is my first post on this forum, and my first attempted to repair a TV.
            My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
            Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
            Read also that we should test what happens if we...
            10-01-2023, 12:06 AM
