Troubleshooting L240AS-00 - fails every other time
    hi there,
    I am trying to troubleshoot the ATX in question.
    I have it connected in series with a bulb.
    It randomly goes into startup trouble where the bulb turns itself fully on, only to work ok right after turnoff/turnon cycle.
    I checked the primary side - caps capacities (including main filtering one), bridge, diodes, transistors, soldered off varistors. nothing blown.
    the PSU is based on ICE3AR2280JZ, datasheet
    https://cdn.badcaps-static.com/pdfs/...1656e817fe.pdf
    Here's a video showing the behavior
    - first switch on - short / loop
    - second switch on - works OK
    - third switch on - short / loop
    https://photos.app.goo.gl/ysfM64W3SYHL7KFH8
    I would appreciate some guiding hand as to where to go next.
    Re: Troubleshooting L240AS-00 - fails every other time
    Okay
    I have two questions for you
    When the power supply starts correctly want are the voltages on each rail
    What happens if you do not have the light bulb in the circuit does it blow the fuse
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      hi there!
      so the results are all good
      3.3 - 3.41V
      5 - 5.06V
      5VSB - 5.11V
      12V - 12,13V
      -12V - -11,26V
      PWROK - 4,68V
      Re the fuse & bulb. I looked into this PSU since it stopped working reliably (randomly turning off).
      I blew the fuse during one of the trial runs - possible short of the probes.
      Now I'm afraid to run the whole thing without it
      by the way - if I don't short PWRON, then the 5VSB is always there and there is no short ...
        BTW ICE3AR2280JZ is just one of the (at least) three ICs for PWM/PFC.
        The other one is FAN4800A. The third one is possibly the same but I can't get to it to confirm.
        https://cdn.badcaps-static.com/pdfs/...3d894205a5.pdf
          a related L240AS-00 post,might help you https://www.badcaps.net/forum/showth...ight=L240AS-00
