la-b991p power up but no video
  • Francisco.s
    • 691
    • Spain
    Hi, have a la-b991p that power up but has no video, no usb mouse or pendrive light, or acces.
    Seems a problem like in this thread:
    https://www.badcaps.net/forum/showthread.php?t=72709
    All voltages are present and main bios/ ec-bios are programmed with good dumps,
    PLT RST goes low and then high, so seems that power up sequence are fulfilled also.
    The weird thing is that there are no activity on spi bus.
    Bios chip also replaced.
    Any comments about this problem?
  • Francisco.s
    • 691
    • Spain
    Re: la-b991p power up but no video
    Sorry, PLT RST goes low and then high and then low, so it is a single pulse.
    I didn't notice that there is some sulfate between pin 1 and 2 of kbc, but I remove the sulfate and check voltage of pin 2 (EC_KBRST#) and get 3v when power-on, so i think it is correct now but still doesn't work.
    I will check carefully the rest of the board, and eventually replace the kbc.
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
      09-06-2024, 05:59 AM
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
