Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 08-06-2019, 03:33 PM   #1
kadird
City & State: istanbul
My Country: turkey
I'm a: Knowledge Seeker
Default Commodore 1084s-p1 fault with video.
Hi all, i have a 1084s and that was working fine until yesterday. But yesterday monitor is suddenly stopped and faulty now.
I want simply upload a video about problem, which parts and areas should i check, can anyone help?
Thanks.
https://youtu.be/qiizl8iJRLM
kadird is offline   Reply With Quote
Old 08-06-2019, 05:43 PM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Commodore 1084s-p1 fault with video.
it looks like a philips chassis, so it could be the line output transformer failed.
stj is offline   Reply With Quote
Old 08-06-2019, 06:37 PM   #3
R_J
City & State: ☻
My Country: Canada
I would first check for a shorted horizontal output transistor or maybe a shorted diode in the power supply secondary. Are you getting any secondary voltages? there is a service manual for this monitor
Being an old monitor I would I would check the small caps in the primary switching circuit and it could also be a bad cap for one if the secodary voltages. This power supply has a triac for over voltage protection and that "might" be the sound you are hearing
R_J is online now   Reply With Quote
Old 08-07-2019, 06:41 AM   #4
kadird
My Country: turkey
Quote:
Yes, it is Philips one. What's the line output transformer, you mean flyback transformer?
Old 08-07-2019, 06:43 AM   #5
kadird
My Country: turkey
Thanks for advices. I dont measure any voltages yet. Only visually controlled around pcb and dont noticed any bad looking caps or transistors. I have service manual, will check soon. Thanks again.
Old 08-07-2019, 06:43 AM   #6
stj
stj's Avatar
yes,
there is a way to test for this.
but first:
remove the flyback transistor and test it.
while it's out, put a 40w lamp ( a traditional one, not led) across the B+ capacitor
it should light up.
Old 08-07-2019, 07:16 AM   #7
kadird
My Country: turkey
yes,
but first:
it should light up.
Okay ill try it thanks
Old 08-09-2019, 01:15 PM   #8
kadird
My Country: turkey
@stj, I cant spot these points in the pcb, is there any detailed schematics or guide somewhere?
Old 08-11-2019, 04:49 AM   #9
stj
stj's Avatar
manuals
Old 08-12-2019, 06:58 PM   #10
kadird
My Country: turkey
thx again, can u give me part numbers in schematics? for example, which one is flyback transistor, 7512?
https://imgur.com/a/KKkkpEw
Old 08-12-2019, 09:54 PM   #11
R_J
City & State: ☻
My Country: Canada
Yes, 7512 is the horizontal output (flyback) transistor
Old 08-13-2019, 03:55 AM   #12
kadird
My Country: turkey
okay, which one is B+ cap then?
Old 08-13-2019, 07:25 AM   #13
stj
stj's Avatar
2520 10uf - you should see 128v across it.
Old 10-19-2019, 03:08 PM   #14
kadird
My Country: turkey
Hello again. I replaced EHT transformer with new one, picture partly came back but another issue appeared now. Here is the video about new situation:
https://youtu.be/GIYkvtMsf28
Where should i check now? Caps maybe or?
Thanks.
Old 10-20-2019, 10:30 AM   #15
kadird
My Country: turkey
I just configure brightness potentiometer on the EHT and problem solved.
Old 10-20-2019, 04:07 PM   #16
stj
stj's Avatar
you must adjust focus and brightness on the transformer.
brightness is often labeled "screen"
you need to do focus first, then brightness, then focus again - because they slightly effect each other.
Old 10-21-2019, 01:31 PM   #17
kadird
My Country: turkey
thanks man, i'll do it again this way.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
