Old 08-06-2019, 03:33 PM   #1
kadird
City & State: istanbul
My Country: turkey
Default Commodore 1084s-p1 fault with video.
Hi all, i have a 1084s and that was working fine until yesterday. But yesterday monitor is suddenly stopped and faulty now.
I want simply upload a video about problem, which parts and areas should i check, can anyone help?
Thanks.
https://youtu.be/qiizl8iJRLM
kadird is offline   Reply With Quote
Old 08-06-2019, 05:43 PM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Commodore 1084s-p1 fault with video.
it looks like a philips chassis, so it could be the line output transformer failed.
Old 08-06-2019, 06:37 PM   #3
R_J
City & State: ☻
My Country: Canada
I would first check for a shorted horizontal output transistor or maybe a shorted diode in the power supply secondary. Are you getting any secondary voltages? there is a service manual for this monitor
Being an old monitor I would I would check the small caps in the primary switching circuit and it could also be a bad cap for one if the secodary voltages. This power supply has a triac for over voltage protection and that "might" be the sound you are hearing
R_J is offline   Reply With Quote
Old 08-07-2019, 06:41 AM   #4
kadird
My Country: turkey
Yes, it is Philips one. What's the line output transformer, you mean flyback transformer?
Old 08-07-2019, 06:43 AM   #5
kadird
My Country: turkey
Thanks for advices. I dont measure any voltages yet. Only visually controlled around pcb and dont noticed any bad looking caps or transistors. I have service manual, will check soon. Thanks again.
Old 08-07-2019, 06:43 AM   #6
stj
stj's Avatar
yes,
there is a way to test for this.
but first:
remove the flyback transistor and test it.
while it's out, put a 40w lamp ( a traditional one, not led) across the B+ capacitor
it should light up.
Old 08-07-2019, 07:16 AM   #7
kadird
My Country: turkey
yes,
but first:
it should light up.
Okay ill try it thanks
Old 08-09-2019, 01:15 PM   #8
kadird
My Country: turkey
@stj, I cant spot these points in the pcb, is there any detailed schematics or guide somewhere?
Old 08-11-2019, 04:49 AM   #9
stj
stj's Avatar
manuals
Old 08-12-2019, 06:58 PM   #10
kadird
My Country: turkey
thx again, can u give me part numbers in schematics? for example, which one is flyback transistor, 7512?
https://imgur.com/a/KKkkpEw
Old 08-12-2019, 09:54 PM   #11
R_J
City & State: ☻
My Country: Canada
Yes, 7512 is the horizontal output (flyback) transistor
Old 08-13-2019, 03:55 AM   #12
kadird
My Country: turkey
okay, which one is B+ cap then?
Old 08-13-2019, 07:25 AM   #13
stj
stj's Avatar
2520 10uf - you should see 128v across it.
Old 10-19-2019, 03:08 PM   #14
kadird
My Country: turkey
Hello again. I replaced EHT transformer with new one, picture partly came back but another issue appeared now. Here is the video about new situation:
https://youtu.be/GIYkvtMsf28
Where should i check now? Caps maybe or?
Thanks.
Old 10-20-2019, 10:30 AM   #15
kadird
My Country: turkey
I just configure brightness potentiometer on the EHT and problem solved.
Old 10-20-2019, 04:07 PM   #16
stj
stj's Avatar
you must adjust focus and brightness on the transformer.
brightness is often labeled "screen"
you need to do focus first, then brightness, then focus again - because they slightly effect each other.
Old 10-21-2019, 01:31 PM   #17
kadird
My Country: turkey
thanks man, i'll do it again this way.
