LG 37LC50C Turns on then off
  • Super360
    • Jul 2016
    • 243
    I have a lg tv here that is one of those commercial tv units. It will power on make a staticky sound then shut off. It does display a picture then it just shuts off what can I do? The psu has good standby voltage as well. I'm wondering if the lamp is dead possibly?
  • Super360
    • Jul 2016
    • 243
    Re: LG 37LC50C Turns on then off
    I think the motherboard has a issue because when I was probing the psu connector accidentally shorted ps_on with 5v standby and it kicked on no issue. I imagine some bga/capacitor issue on mainboard. I'm buying a new motherboard and will report back.
    • Super360
      • Jul 2016
      • 243
      So I replaced the motherboard to have it do the same thing now I'm thinking it's the backlight inverter is there anyway to test these things.
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        Did the backlight work with the ps-on test?
        Report the voltages on the inverter cable, 24V and bri, dim and the other two.
        • Super360
          • Jul 2016
          • 243
          Yes the backlight turns on with ps_on test.
          ADC= 4.18V
          ON/OPFF= OFF MODE=0.0051V DC 2.74V IN ON MODE
          5T5V=5V
          5T5V=5V
          5V= 0.500V
          3.4_ON= 2V WHEN POWER IS ON 0.055V WHEN OFF
          • Super360
            • Jul 2016
            • 243
            18V=18V WHEN POWER IS PRESSED ON. 7v when power is off
            18v=18V WHEN POWER IS PRESSED ON. 7v when power is off
            6v= 6when power is on 0.700v when power is off
            3.4v= 3.5v when power is on 0.700v when power is off
            12v= 1.300v when power is off 12 volts when power is on
            • Super360
              • Jul 2016
              • 243
              dim=3.3v when power is on 0v when off
              i-c=5v when on 0v when power button is off
              bri= 1.69v when on 0v when off
              All the 24v are 24v when the power button is pressed on 0v when off
              • Biruslapio
                • Nov 2013
                • 552
                • Brasil
                The voltages are fine except for the 5V pin. You must have noticed that too, Now I do not know if it's actually used by the TV, since there's 6V going to the mainboard, trace to find its source on the PSU board.
                If the backlight stays on during the ps-on test it's not the inverter, the signals (bri, i-c, dim) that the mainboard is sending are normal.
                • Super360
                  • Jul 2016
                  • 243
                  Ya I cancelled the inverter theory and now I'm just gonna chuck a used psu into it.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    service manual if needed
                    • Super360
                      • Jul 2016
                      • 243
                      I bought a repair kit for this psu. https://www.ebay.com/itm/tkit28-LG-3...-127635-2958-0
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        i think these repair kits only have 6 capacitors in them fixes
                        SLOW START UP
                        STUCK IN STAND BY
                        C204
                        C205
                        C221
                        C222
                        C223
                        C232
                        • Super360
                          • Jul 2016
                          • 243
                          Well seeing as how you made it easy I opted to just buy the caps outright instead much cheaper.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            How i usually find whats in the repair kits and location of parts is too look on ohm supplies web site, kit kit103 is for your psu (good company i have used them a lot here in the uk)
                            • Super360
                              • Jul 2016
                              • 243
                              LOL I was like how did this mf find all these capacitor values. I was searching through the listing trying to find what you saw lol thank you man. Will give ya guys a update when these low-esr ebay special arrive.
                              • Garion60
                                • Jan 2022
                                • 6
                                Looking forward to learning what worked/didn't work. Good luck!
                                • Super360
                                  • Jul 2016
                                  • 243
                                  Well update replaced all those caps to have it keep doing the same thing damn.
                                  • Super360
                                    • Jul 2016
                                    • 243
                                    I think either the screen or the tcon or something I don't know bout to toss it.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      does the backlight flash on and off i wonder if this is a 2 second too black fault as ccfl set
                                      ignore the above, i see you can trick the backlight to stay on so not that.
                                        • 12096
                                        • U.S.
                                        One of the first and least expensive things you can do when you have an issue is take the powerboard out of the tv, flip it over and look the solder joints over with a magnifying glass if needed, add a little flux to make the solder flow well and add solder to any joints that look even a little suspect. You can practice on a scrap pcb board if needed, careful not to bridge any joints, and always let the board sit for quite a while or discharge the big caps with an appropriate resister before working on it (safety first) to try to keep from getting shocked, it doesn't take 1000 volts to KILL, a lot less can kill, so be careful, it's only a tv.
                                          Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPANISH MEXICO HDWR COMMERCIAL PLAT boardview and SPANISH MEXICO HDWR COMMERCIAL PLAT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 12:40 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
