Xbox 360E model:1538 not turning on
    Hello everyone!
    I have two same console with same error. Not turning on.
    Model:Xbox 360E model:1538
    The power birck led is lights on amber.- Tested with this methood. Link
    I measured the power button circuit to power panel connector, everithing looks good. local console guru said, southbridge error--> I replaced it with new.. same error.
    Can't find schematic or any document for this error.
    Can somebody help me?
    Re: Xbox 360E model:1538 not turning on
    is the psu giving 12v?
      Yes,
      5V stand by is present, and when the psu is on, 12V present based on video
        A common cause in slims (does not turn on) is a problem in the 3.3v DC converter (in 5v - out 3.3v).
          Thank you.
          I measured 5V is present the 3.3V just 0.28V
          I not found this tiny voltage regulator name, type or any datasheet.
          Is there any solution to bypass or change to other components?
          I found article in which he mentions, to replace with AMS1117.. it is working?
            Yes, you can put AMS1117 3.3 with a fixed voltage of 3.3v
            "J7(X)" is "RT8057"
            Sometimes they put: "CEY" - That is "TPS62560"
              Thank you, so much!
                working!
                Thanks!!
                  Originally posted by tsiga View Post
                  working!
                  Thanks!!
                  I like your repair this has a very professional look to it
                  One more item that did not end up in the landfill
                  Very nice work
                  9 PC LCD Monitor
                  6 LCD Flat Screen TV
                  1 Dell Mother Board
                  15 Computer Power Supply
                  All of these had CAPs POOF
