Vestel chassis firmware update required Celcus DLED32167HD
    Hi
    TV has only been used a handful of times and now suffering from flashing standby light issue were the TV intermittently switches on.
    It appears the website that hosts all the vestel firmware is down (vesteldriver.com), and cannot find the correct firmware.
    I found a firmware file from another site (upgrade_loader.pkg) unpacked the rar file and copied it to a FAT32 formatted usb stick and tried both methods to update (using service menu and holding down OK button while powering up TV) however TV not finding file.
    I have managed to get into service mode and taken a photo of the TV spec.
    Please let me know where I can find the correct file to download and how I can obtain chassis type to help me Google the correct firmware file as I understand from other posts there are several variants .
    Thanks!
    Re: Vestel chassis firmware update required Celcus DLED32167HD
      Maybe try this site if you have not already
      http://www.vestelservice.com/VestelS...UserLogin.aspx
      Depending on which one you want
      Argos (Bush, Digihome)
      User VS889106
      password ARG52S
      Luxor
      User VS847338
      password LUX827OR ( that's the letter O in there)
      That should get you in to either site.
      To look up software
      Click brown goods - products - software
      Then enter the set's serial number preceded by the number 2 ie (2)7097437 (taken from the back cover of the set)
      Click search and hopefully they'll have it.
      Also worth noting that clicking on extras in the top menu's will give access to MB, PW and IPS circuit diagrams.
      The site is a bit fiddly to use,But should be extremely useful!..Bit late on this thread,just spotted it!...(User and password must be in block caps)
      Edit! this site does work for some reason though not in firefox and google chrome but in blue sky browser works fine
        Hi
        Many thanks for your reply.
        Tried both logins and couldn't find TV by serial , model or and product id. Tried pressing search also with the field blank which appears to list all TVs assigned to the login, and couldn't manually find it. ☹️
        The TV was purchased from Sainsbury's in the uk
          does yours use the 17MB82 mainboard ? if so i would try again with the 17MB8X Core Software Update file im sure their are a few threads on this site regarding this have you tried freeze spraying the eeprom ic does the set start up ok then each time its froze? im just wondering if its a faulty ic
          what lcd panel number is used in this set?
          have you tried ohm supplies they maydo a pre programmed ic or usb stick
          This is the core update file i have you could try this at your own risk as i havnt tried it myself
            Many thanks for the following link which has worked well for some time--
            However ive noticed that its no longer available. Anybody know of the new link details??
              http://www.vestelservice.com/VestelS...UserLogin.aspx this link works for me ive just logged in fine im using bluesky browser
                If anyone's Celcus TV is suffering from the same symptoms as my original post then suggest calling the Celcus support number 0800 636 262 and they should send you a CD with the firmware. They will not send it via email or any other form. Let me know if anyone needs the firmware for this specific TV and the steps to load the firmware.
                  Glad to report link now works must have been a temp glitch!
                    Hello Jondoe66 I have software problem ,have you got that software if yes ,can you share it please?
                    many thanks
                      i have uploaded the firmware. Extract the files on a formatted spare USB stick and then follow the steps in the photo.
                      Not this worked for my specific TV model, so suggest checking it's suitable for your TV as will not be responsible for bricking your TV
                      Hope this helps
                      Regards
                        Well I need the 17MB82S firmware. Can I use the 17MB82 one you've provided ? I tried but my TV refuse to enter on it. I tried something with a completely other one and with some trials and errors, I manage to have a totally glitched menu, but another menu.
                        I will keep trying but that's very long to do.
                          I could not solve the site in a way, even if I wrote a serial number on the software, I could not find anything, is there any video or someone who can tell
                            hello all,I have the same problem with the inverted image, but the model differs I have 17MB82S, can someone help me please ..thank you
                              what lcd panel number is used in your tv it should say on a white sticker on the metal chassis somewhere.
                                tip, try putting a * before and after the MB number..e g..
                                *17MB*
                                youll get a list of all the 17MBxxx models then.
