Modified RTX3000 series BIOS files with memory channels disabled
    Hi All
    I was looking for ways to disable memory channels in BIOS for a GTX 980 (found nothing) - however I did find a load for RTX3000 series cards - file name describes which memory channel is disabled and for which card - maybe of use to someone with a card that has a bad memory controller (and ram chip is good) to get the card running again with slightly less RAM.
    They look to be from Gigabyte cards originally.
    Re: Modified RTX3000 series BIOS files with memory channels disabled
    I've been looking for the same software for a gtx 1080 ti
    With one bad Chanel.
    Sure there must be some way to disable a chip by moding the bios/ firmware.
    Anyone when to add to the topic?
      looking for the same in a 3080ti with a bad ic . it turns out its the E1 chip location but may have bad connection under the core. im not tryint to reflow it with my skill. dont mind a cheap 3080ti with less memory. it was cheap
        3080ti is in those BIOS files
