Hp 15-dw3000 GPT52 LA-K201P REV 2.0
    Dear Friends,
    any one help me, Please clean Me.
    Re: Hp 15-dw3000 GPT52 LA-K201P REV 2.0
    The one you posted is a virgin bios,so the ME is clean. Check it with MEAnalyzer (Configured = Clean , Initialised = Dirty). If it isn`t booting with that bios the problem is somewhere else,thats assuming that 0881D is the right one for this model, there`s another 3 16MB bios you can try.
    https://github.com/platomav/MEAnalyzer/releases
    Link to bios download https://ftp.hp.com/pub/softpaq/sp113...0/sp113998.exe .Run the exe to extract,and choose the copy option.
      Ok thanks
        This bios is right for this model, and I flash it to laptop and work fine, when shutdown laptop and leave it for a while and try to startup again, its start with black screen. flash it again work then black screen. five times same problem.
        any ideal?
          any ideal?
          Replace the SPI Flash (bios chip) with a new one.
            Replaced it with another one same problem, not same number but same capacity. work fine after shutdown, turn on then off.
              Any ideal
                Plz send me working bios
                  Have you read post #2
                    Here is DUMP extracted from working laptop
                      Any ideal
                      I was tried to update PMC firmware, hope it can help you.
                      Become a Badcaps supporter
                      Thanks to all supporters.
                          working
                            Thanks for the info sir
                              HP bios LA-K201P REV 1.0
                              their friends I have this hp notebook
                              model : 15-dw3017nt
                              serial : CND120557V
                              there was fluid contact .. I solve all problem but about bios I cant solve
                              On the board there is 8 mb bios .. Ifind 2 of 8 mb and the other 16 mb
                              can you look and say something .. this is back bios
                                thanks sir but not use, i have problem with 3 long 2short led blinks, after the programme also same problem.... any body can help
                                  post the full name and model of the laptop S/N..and the original bios even if it is corrupted.
                                    Gpt52 la-k201p rev:3.0
                                    i wanat bios file
                                      i wanat bios file
                                      Read post #17.
                                      Thanks to all supporters.​
