Dell Latitude 5430, LA-L591P Computrace setting unlock
    Re: Dell Latitude 5430, LA-L591P Computrace setting unlock
    Originally posted by biniu1978 View Post
    my chip is - 25Q256JVEN
    and my programmer have only that option - reading all same.
    see picture
    This option should be fine. Which adapter do you use to connect the WSON Chip to your Programmer?
    all donations are welcome,
      Chip is connected directly to programmer without any adapter ( wire connection )
        So you solder the wires to the Chip pins? Attach an Image for your connections, you may use long wires.
          hi can anyone please unlcok this dell 5430 bios thanks in advance
            try and replay
              Originally posted by farouk_1994 View Post
              try and replay
              thank you so much work perfect tahya ness oran
                bios with admin lock , Please Unlock
                Dell Latitude 5430
                8FC8
                Thank You
                  Dell Latitude 5430
                  8FC8
                  Thank You
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                    yslmk frere any thing i'm here
                      Originally posted by Vesko356 View Post
                      working perfect .Thank You
                        Please help unlock bios dell latitude 5430
                          Here's your Unlocked BIOS, hope it works fine.
                            Thanks worked
                              Hi, please unlock this bios.
                                  Thank you so much! I'm so grateful!
                                    You're welcome. Cheers.
                                      hi guys! can you help me unlock this 5430? admin pass and safe bios! thanks!
                                        Your Dump file isn't good, try to read it again correctly.
                                          i re-read it 2 times with the same programmer and 2 times with another programmer.. it is 25Q256JV and it has the same checksum..
