The Hall of Shame - Badcaps Photo Montage
This is a sticky topic.
    Re: The Hall of Shame - Badcaps Photo Montage
    If a large can capacitor (like the Elna a few posts ago) feels lighter than expected, you could have a fake on your hands.
      in my case fake ELNA is very weight, because inside them filling up with something like bitumen / asphalt that stinky.
        Here are some good ones...
        The first two are a FU-YU and a Jackcon pulled from an Emerson ghetto blaster that was made in 1999. I think the first brand nane would be more appropriate if they left out the first U.
        Next, there is a JEC that was pulled from a set of computer speakers. I measured 11.38V across it, and it is only rated for 10V.
        Finally, there is another set of computer speakers that is full of Fujicon caps. The two that are bad are the output coupling caps.
          I just remembered that every Fujicon cap except for the four 0.47uF 50V caps were bad. I don't have an ESR tester, but they all had very low capacitance. The 0.47uF caps gave me the correct capacitance value.
            Skywell caps are bad too. I should be able to provide a picture. Should I?
              Successful recap-Dell Dimension E521. Rubycon 6.3/1800 MCZ's with some Pannys
              edit: Yes I know its an nvidia 6 chipset with some KGZ's. but if the thing has lasted this long with a COMPLETELY blocked airflow, those KGZ's are probably going to be OK. Most of them are under 470uf, everything else is rubycons (except for the pannys I put in)
                And you're calling other people nerds?
                https://www.badcaps.net/forum/showpo...2&postcount=12
                WATCH OUT! - This guy is a nerdist!
                Mann-Made Global Warming.
                - Dr Seuss
                  its sarcasm. get used to it
                  i'm a nerd too, but not like you. You make money, have better equipment, have much more XP, have gotten laid
                    Smithfield (90nm) Pentium D's in an SFF case can apparently kill a Rubycon:
                    Also some swelled up KZJ's.
                    It's an SFF Dell Optiplex 745.
                      I'd say it's time for a poly-mod.
                        Sorry, new here, but I presume you're saying I should replace them with polymers?
                        I'm definitely going to upgrade to Core 2 if I resuscitate this thing. An E6300 is $30 used and is faster, uses less power, and runs cooler.
                          Yes, I meant replace with polymers.
                            Another explanation: The KZJs bulged (they have heat issues) and the Rubycon took all the ripple... Combine that with the heat of the Pentium D in as SFF case and here is what made it fail.
                              As far as I know legitimate MCZ come in black with gold lettering, not black with white lettering.
                              May have been previously recapped by someone that got counterfeit caps on ebay.
                              - Dr Seuss
                                No, MCZs do also come in black and white like B757's board. I have seen it and so has topcat. My guess would be that the black and white ones are
                                from a Malaysian or other non-japan rubycon factory.
                                  Unless the vents are shaped like these.
                                  http://cgi.ebay.com/NEW-Rubycon-6-3V...item53e79d0c90
                                  There is too much crud on that cap to see the shape of the vent.
                                  - Dr Seuss
                                    those are so fake its funny, it looks like they're not even trying, look at that one with the label pulled up almost all the way up
                                      Not to mention the wrong vent.
                                      - Dr Seuss
                                        These are 250V 150UF Samyoung caps in a plasma TV.
                                        I didn't notice the bulgy ones until I looked at them at a low angle.
                                        When I put a straight edge across them they were bulging the thickness of the plastic sleeve.
                                          KZG caps from a Biostar S939 mobo
