Thread Tools |
#1001 |
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
![]() is the case also a total pile of shit to match?
#1002 | |
City & State: Williamsburg, Virginia
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
![]() Quote:
Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11) |
#1003 | ||
City & State: Tamaulipas
My Country: Mexico
Line Voltage: 115VAC 60Hz
![]() Quote:
Not really, it's a cheapo uATX case but the quality is nowhere as bad as the P/S, these cases usually came with very low end KeyMouse units inside very similar to this one but this is the first one that I've seen with an LC. Quote:
#1004 | |
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
![]() Quote:
![]() That said, you could still easily make it a usable PSU again. Since there is only a single cap for the 12V and 5V rails, looks like you have a lot of space there. Maybe change those caps with 12.5 mm ones? That gives you the option to put a 3300 uF 16V cap on the 12V rail and a 3300 uF or 4700 uF on the 5V rail. The 3.3V, of course, should be more than happy with two 2200 uF caps (and if the PSU won't be powering a power-hungry motherboard, you could probably go as low as two 1500 uF caps). As behemoth suggested, though, I too wouldn't recommend you put big filter caps on the 12V rail where the fan connectors are. With the long traces going to those connectors, you may introduce undesirable noise in other nearby traces, and that may or may not cause problem. Those coils on the 5VSB probably don't make a overly-huge difference in suppressing output ripple anyways. But I'm sure it helps with the ripple current on the caps, though. Looks like you could install one. The jumper in position L4 (or is it J9?... or J10?) right next to the output caps could be replaced with a coil. ![]() More likely, it stands for Horrible Quality ![]() Wow, that is clean work! Last edited by momaka; 08-17-2014 at 09:52 PM.. |
#1005 |
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
![]() Well, you can put 3300uF 16V caps in D10 there as well, the Samxon RS, soon also NCC KZN…in D12,5 I think you can get as high as 3900 or 4700 uF in 16 V.
Less jewellery, more gold into electrotech industry! ![]() ![]() Exclusive caps, meters and more! Hardware Insights - power supply reviews and more!
#1006 | ||
CapXon Be Gone
City & State: Idaho
I'm a: Hardcore Geek
![]() ![]() Quote:
I have Panasonic FR 4700µF 16V D12.5mm but that might be too low for the PSU? ESR for that cap is 0.012Ω |
#1007 |
My Country: CZ
![]() Just try. As there is no Pi filter, who knows, it can probably handle a lot…
#1008 |
CapXon Be Gone
City & State: Idaho
![]() Fan seized in this thing, which was causing the computer to shut down. Man, this thing is pretty bad. Looks like it is made by ATNG? Those Y caps and X cap are safety approved. At least I'll get a few useful parts out of it
#1009 | |
Capaholic
City & State: Trenton, NJ
Line Voltage: 240/120V 60Hz
![]() Quote:
The other day I found a fake EMI filter inductor in my inductor box, and yours looks just like the one I found. It was quite lightweight, and when I unwound it, and took the plastic shells apart, there was no ferrite inside!!!!
Muh-soggy-knee |
#1010 |
My Country: CZ
![]() Definitelly not ATNG, some generic chinese crap, I've seen similar ones. ATNG uses different heatsinks for a start.
#1011 | |
CapXon Be Gone
City & State: Idaho
![]() Maybe it's Long Yi Electronics.
#1012 | |
Capaholic
![]() Quote:
I was sorting things and did a double-take, I realized that choke was suspiciously lightweight... inspected it, then I unwound it... FYI, the choke needs the ferrite to work as intended, it is a common mode choke. |
#1013 |
CapXon Be Gone
City & State: Idaho
![]() Here's another junker. It's pretty terrible, but not the worst I've ever seen. If you add up all the rails' wattage on the label, it comes out to 275W
![]() ![]() Last edited by Pentium4; 08-28-2014 at 08:59 PM.. Reason: Typo |
#1014 |
My Country: Mexico
![]() Yeah crappy indeed, specially the lack of output coils and/or place to install them, but, interesting in some ways like the 5VSB switcher, it has a weird numbering on it, resembling a Unisonic part but the "WY" logo is not from Unisonic, probably a knockoff, P/S controller chip it's the Silan's version of SG6105 but IIRC Silan already have one version, the SD6109
![]() Samwei caps? ![]() Main transformer doesn't look that bad, I mean, we all have seen smaller ones, if it weren't for the lack of output coils I could trust it to power a very low power system like those onboard atom/celeron/APU after a proper recap. edit- I've posted all Samwei DS in the cap depot thread. Last edited by SIDMX; 08-29-2014 at 12:56 AM.. Reason: link to ds. |
#1015 |
CapXon Be Gone
City & State: Idaho
![]() Wow you know what, I'm so used to seeing ChengX in that green/gold sleeve that I didn't even notice that they're SAMWEI
![]() And here's a size comparison, that transformer is a lot smaller than the earlier pictures resemble. |
#1016 |
My Country: Mexico
![]() Yeah at first sight I took them for ChengX too
![]() Ah!... that winding is tiny! it is using like half the space available in that core, still could be enough for Atom boards, but it is definitely crappier than I thought. At least is not a real joke like this one that I found in an LC. Last edited by SIDMX; 08-29-2014 at 12:09 PM.. |
#1017 |
CapXon Be Gone
City & State: Idaho
![]() WHAT! That was a main transformer?! That's pitiful
#1018 |
My Country: Mexico
![]() Cutting the circuit shouldn't be a problem, but you'll need to ID that switcher and get the DS to understand what (if any) changes are needed to successfully "implant" it into another P/S, also note that the feedback for SB is done using one of the two built-in shunt regulators (TL431) in the SC6105 chip.
#1019 | ||||
master hoarder
My Country: U.S.A.
![]() Quote:
![]() Althoug that Jin Yuan has no space for PI coils on the secondary side, it looks like there is a lot of space next to the caps and the tracks for the rails on the solder side are wide enough, so they could technically be cut up and have a PI coil added. But meh... why bother with that. Just use the parts to fix up a better PSU ![]() Quote:
-Aw, isn't that cute? But it's wrong! ![]() Quote:
The easiest way would be to take the 5VSB transformer from this PSU as well, so that way you can transfer the entire 5VSB primary side on the new PSU. As for the feedback - almost all 5VSB circuits I've seen use a 431 shunt. Usually the compensation is a simple RC network and very similar between PSUs, so you may not have to change it all, unless the 5VSB has a hard time "keeping up" or overshooting with a load. Last edited by momaka; 09-05-2014 at 08:49 PM.. |
#1020 | |
![]() Quote:
Thread Tools | |
